I have a "Code Alarm Remote Start Model CA-671" already installed on my Expy and it has a "Trunk open" Button on the remote
(Located on the side of the LCD remote) You can see a picture here:
http://www.audiovoxproducts.com/images/common/CA671/addl/CA671_1.png
First thing first, I went online to lookup the installation manual for the CA-671. Once I found that, now I know which wire to tap into.
Installation Manual:
http://documents.codesystems.com/701597.pdf
Opened up my Dash (middle woodgrain section) to get access to the Liftgate Switch Connector. The wire I need to tap into is
gray/yellow.
Next, I spliced it together with my other wire
(I picked this yellow 18 Gauge wire I had laying around), then fished it through the Dash panel, behind the foam padding until I reached my Alarm module. (Nice and Clean install, outta sight, outta mind)
On the Alarm Module, I tapped into the "TRUNK OUTPUT" wire to connect the yellow wire mentioned above and link the two together.
Note: color will vary depending on your alarm make and model, but in this case the wire was Red/White.
Last but not least, I set the fuse for the Trunk Polarity (On the Alarm Module) to Negative polarity.
Since the LiftGate Button on the Dash is used for both Open and Close action, it made this install very simple.
... Don't hesitate to hit me up if you have any questions.
