2000 Eddie Bauer
gerke74
Wyoming
I leve a 2000 Eddie Bauer Ford Expedition. It has the Triton 5.4. I have replaced all 4 O2 sensors, and the charge air temperature sensor. Reset the computer, and it drove great for 5 hours. Now runs rough does not want to start and smell raw fuel. It was getting 19mpg, now getting 9. Ran diagnostic, came up lean bank 1 , lean bank 2, O2 lean bank 1, sensor 2, O2 lean bank 2, sensor 2, air temp sensor high input.... What the heck is going on? Is there another air temp sensor for the engine?
Bedrck47
Elizebethtown, PA
get the codes read check for vacuum leaks make sure you got all the o2 sensors connectors properly connected or if you bent any pins when reconnecting
1955moose
You got 19 mpg? I've got a 2000 4wd that gets 9-12 mpg. Sounds like you've got a bad new sensor. Did you keep the old ones? Might have to sub in the o2 sensors 1 at a time till you get problem fixed. Check all pins, wires, when you get apart. Like I've always told friends over the years I'd rather screw up my car or truck 3 times than pay someone to screw it up once. It's only your free time. One last thing make sure the o2 sensors are right for your motor. If you can return them pay the diff and get Ford units, they almost always work better than aftermarket parts.
01yellerCobra
San Diego
Since it's throwing codes for all four sensors I'm going to say that those likely aren't the culprit. I'm going to say the IAT sensor is bad. If it's not reading the correct air temp it can throw all kinds of things off. Like how much timing the ECU can add for the air temp. If you still have your old one I'd throw it in and see what happens.
G
gerke74
Wyoming
I have checked all four O2 sensor plugs, and they are plugged in tight. I will try putting the old charge air temp sensor back in. I have found that if I place a finger over the sensor in the air box it straightens out... What is the sensor in the air box? The charge air sensor is in the tube that connects the air box to the intake.
Bedrck47
Elizebethtown, PA
there are two sensors in the intake the Mass airflow sensor and the Intake air temp sensor
can you take a picture of what you are referring to
The Intake Air Temp Sensor will have a TWO WIRE CONNECTOR
The Mass Air Flow Sensor will have a FOUR WIRE CONNECTOR
G
gerke74
Wyoming
The one I replaced is the push in grommet type from the first picture. It was located in the tube between the air filter box, and the intake.
G
gerke74
Wyoming
The exact codes are as fallows.
PO 171
System lean to bank 1
PO 156
O2 circuit bank 2, sensor 2
P1131
Lack of HO2s11
Switches/sensor indicates lean.
P1151
Lack of HO2S11
PO136
O2 circuit bank 1, sensor 2
PO174
System lean bank 2
PO113
Intake temp sensor 1 circuit high input.
This all started when the temp return here in Wyoming dropped.
Bedrck47
Elizebethtown, PA
P0113 - Intake Air Temperature (IAT) Circuit High Input
Indicates the sensor signal is greater than Self-Test maximum. The IAT sensor maximum is 4.6 volts or -50°C (-46°F).
Open circuit in harness
Sensor signal short to power
Damaged sensor
Improper harness connection
Damaged PCM
P0136 - HO2S Sensor Circuit Malfunction (HO2S-12)
The downstream HO2S sensor(s) are continuously checked for maximum and minimum voltages. The test fails when the voltages fail to meet the calibrated limits. Pinched, shorted, and corroded wiring and pins.
Crossed sensor wires.
Exhaust leaks.
Contaminated or damaged sensor.
P0156 - HO2S Sensor Circuit Malfunction (HO2S-22) See DTC P0136
P0171 - System to Lean (Bank 1)
The Adaptive Fuel Strategy continuously monitors fuel delivery hardware. The test fails when the adaptive fuel tables reach a rich calibrated limit.
For lean and rich DTCs:
Fuel system
Excessive fuel pressure.
Leaking/contaminated fuel injectors.
Leaking fuel pressure regulator.
Low fuel pressure or running out of fuel.
Vapor recovery system.
Induction system:
Air leaks after the MAF.
Vacuum Leaks.
PCV system.
Improperly seated engine oil dipstick.
EGR system:
Leaking gasket.
Stuck EGR valve.
Leaking diaphragm or EVR.
Base Engine:
Oil overfill.
Cam timing.
Cylinder compression.
Exhaust leaks before or near the HO2Ss.
P0174 - System to Lean (Bank 2)
The Adaptive Fuel Strategy continuously monitors the fuel delivery hardware. The test fails when the adaptive fuel tables reach a rich calibrated limit.
See Possible Causes for DTC P0171.
P1131 - Lack of HO2S-11 Switch, Sensor Indicates Lean
A HEGO sensor indicating lean at the end of a test is trying to correct for an over-rich condition. The test fails when the fuel control system no longer detects switching for a calibrated amount of time.
See Possible Causes for DTC P1130
P1151 - Lack of HO2S-21 Switch, Sensor Indicates Lean
A HEGO sensor indicating lean at the end of a test is trying to correct for an over-rich condition. The test fails when fuel control system no longer detects switching for a calibrated amount of time.
P1130 - Lack of HO2S-11 Switch, Fuel Trim at Limit
The HEGO Sensor is monitored for switching. The test fails when the HO2S fails to switch due to circuit or fuel at or exceeding a calibrated limit.
Electrical:
Short to VPWR in harness or HO2S
Water in harness connector
Open/Shorted HO2S circuit
Corrosion or poor mating terminals and wiring
Damaged HO2S
Damaged PCM
Fuel System:
Induction System:
Vacuum Leaks
PCV system
EGR System:
Leaking gasket
Stuck EGR valve
Base Engine:
Oil overfill
Cam timing
Exhaust leaks before or near the HO2S(s)
Bedrck47
Elizebethtown, PA
The DPFE sensor is located on the drivers side of the engine Look at the exhaust manifold and you will see two rubber hoses the connect to the riser pipe that comes off the exhaust manifold and goes to the EGR valve follow those two rubber hoses and you will see that they connect to the DPFE sensor
G
gerke74
Wyoming
Ok, I took pictures of the charge air temperature sensor in the breather tube, but I do not know how to put them on here from my phone. :-(
G
gerke74
Wyoming
There is a sensor in the housing of the air filter, on the engine side of the air filter. If I block it with my finger it runs fine. What is that sensor?
