I'm at a loss
jwt40
Sand Springs, Oklahoma
Hello all, I have an 04 expedition 5.4 Eddie Bauer with over 287,000 miles on it. I can't keep it running for the life of me. It just chugs and dies. I thought it was the bank 1 catalytic converter so I had that replaced and it didn't fix the problem. It was throwing codes for the o2 sensors on bank 1 so I thought the converter was clogged. I've checked the pcv valve and it's good and I can't find vacuum leaks anywhere. I will mention that both o2 sensors on bank 1 are brand new and after they were replaced, they were throwing codes saying they were stuck lean. Im relatively new to expeditions in general so im learning as I go. Any advice on what to look for or what to do would be greatly appreciated. Thanks!
AWAR
oregon
Fuel pressure issue? I am replacing the injectors on my 03 Navigator this week.
Put a fuel pressure gage on it and check pressure and flow. Key on engine off should be about 39psi. There is a filter next to the tank ahead of the driver’s side rear tire. The cover over the filter is difficult to remove, plastic is getting brittle on our old rigs.
Gary Waugh
Princeton, TX
I would be checking your fuel pump and fuel line pressure first. A failing fuel pump will cause all the issues you describe and is an easy fix, you can usually rent a fuel pressure tester at autozone and check the pressure in a minute.
kep5niner
Army
MO
Intake manifold. What specific codes are you getting as well?
texasscot
Kerrville, TX
As a possibly failing fuel pump is being mentioned as a cause i'll throw in the failing fuel pump relay as a potential also.
dlascoskie
Sorry for seeing this post so late. Hopefully you still have the truck and were able to sort out the issue. It sounds very similar to an issue I had with my 06 earlier this year. It turned out to be the throttle body sensor. What a headscratcher of an issue to track down. Good luck.
No members online now.
kdp4
