battery terminals
IMINYOURCHAIR
Altoona Alabama
Getting a voltage drop of .240 from the posi terminal. I've already cleaned them before but it's getting worse again. anyone care to point me to a good set of terminals I can use? I can't afford to cut fresh copper as some a$$hat has already cut it as short as it can go
stamp11127
Temple, Georgia
Your problem is the cable, really not the terminal. I'd hit the junk yards for "good" OEM cables and get rid of that junk. Any time you have copper exposed to the elements you will get corrosion - which will add to your problem.
I
IMINYOURCHAIR
Altoona Alabama
Yeah I hear you there. I plan on doing just that but in the mean time I have what I have. If I can get it until I can get the proper wire that'll do
stamp11127
Temple, Georgia
The reading is showing it is slightly out of spec, something you can live with for a while but it should be fixed asap.
As the corrosion gets worse starting the truck will be harder on the starter / battery combination.
I
IMINYOURCHAIR
Altoona Alabama
i fixed it! new readings are at .021 and .013 starting and idling the positive terminal was internally corroded where the wire connected,
I managed to get just another inch of wire out to get some crimp terminals on where I then crimped them and then soldered them using a propane torch to get enough heat to melt the solder this should permanently prevent any corrosion internal to the new connections and act as a great weather barrier. I will seal off the exposed copper when I get daylight and the proper stuff to do it.
the pictures aren't pretty since it was dark out but all is well for now.
stamp11127
Temple, Georgia
Treat the posts and terminals to guard against the vapors coming off the battery or you will have the same problem again.
I use the red and green felt from Wally World, coat the posts/terminals with used motor oil. Lightly of course.
I
IMINYOURCHAIR
Altoona Alabama
what I was thinking about doing is using dielectric grease inside of a heat shrink tube and shrinking that over it up to the crimp. I'm not having any corrosion problems at the terminals, they have stayed rather clean, it's just the copper that isn't happy.
stamp11127
Temple, Georgia
Doesn't look like the battery is a sealed type so it vents sulfuric acid and water vapor during the charging cycle.
No need to use the grease. Heat shrink tubing will work, should have put that on before soldering the ring terminals on the cable.
I
IMINYOURCHAIR
Altoona Alabama
well, with the wind steady at ~5-10 mph, I would've never got a lighter to stay lit and the torch was too much for that and I need it running more than I need that cable to be perfect right this minute. I will try to slip a tube over it but the smaller one will be a pita since it's ring is much wider then the wire. it's just one of those things where you gotta weigh the risks.
and yeah, I am pretty familiar with lead acid batteries and corrosion. it just doesn't seem like this battery is giving any fuss with it's gasses so as to cause corrosion from that. the corrosion I see here looks more like weathered corrosion than it does like battery acid vapor corrosion. but either way I do agree, I should get them properly covered. thatll end up waiting till after the rain stop after sunday.
I apreciate the help man!
I
IMINYOURCHAIR
Altoona Alabama
something I didn't notice earlier, the truck starts with much more vigor now so I imagine that .2xx voltage drop had quite the effect when it was remedied
I
IMINYOURCHAIR
Altoona Alabama
stamp11127, I finished it off this morning, dielectric grease packed around the wire and covered with heat shrink tubing. the posts and screw terminals also got a coating of it.
stamp11127
Temple, Georgia
You have coated the post and terminals with a grease that is an insulator - not designed to be used in that fashion. At those connections you don't want resistance there. Better to use a corrosion inhibitor.
I
IMINYOURCHAIR
Altoona Alabama
well, it must've pushed it out of the way where the connections are made, the voltage drop is still good and it's starting fine, for now, it'll work to keep everything from corroding.
98EXPnSRQ
Sarasota, FL
Instead of the grease, after I tighten the terminals, I spray them liberally with some clear coat paint making sure to get under it and all the cracks covered.
I
IMINYOURCHAIR
Altoona Alabama
okay, the problem is back but I have found why. what looks like a ground wire to the engine block near the starter has the insulation cut about 3 inches up the wire and the cut is about 1/2 inch long. it is corroded into the wire as far as I can see. looks like I will be replacing both runs in the future if I can't just replace a section of the copper.
I found this when I was chasing a coolant leak and was looking right at the problem with the no start while under there.
