Sky jumper- your right, it's a little too pretty boy for me as well. But it's a start. I like the idea of a 10 inch suspension lift and 39.5 inch tires. I'd love to do a similar set up and continue on to make a "low dollar" bogger![]()
It is not the too pretty thing I was refering to, it is the stock axle setup with that big of a lift and tire combo. It just begs for breakage, if you build it and put that kind of money into something, then do it right, and use larger axles to handle the increased tire size and load.Originally posted by babysilk
I think I recognize the truck. He ended up totally the truck not to long ago because the front hub exploded on the truck and the tire fell off of the truck and that steered him into a ditch. needless to say, it messed the truck up pretty good.
def looks like a fullthrottle or whiplash suspension lift.... all show no go.... seen a few of them at shows and they always looked cheap
if the wife allows...
But then I'd have to go bigger then 40"
