What is the bolt pattern?
G
Guest
Guest
What is the wheel bolt pattern on a 1997 Expedition 4x4?
Thanks
rwinch
Walkersville, MD
LandShark,
Actually, now that I look at it, it does NOT show the Eddie Bauer model which has 17" wheels. Good for the others though....
G
Guest
Guest
Will the EB & XLT have the same bolt pattern even though they have different size wheel options?
Guess I should have looked first... 5 x 135 should be it since I have the XLT with 16's ...
Thanks Again...
PaulC
NE PA
All 1997-2002 Expeditions have a 5 x 135mm bolt pattern regardless of rim diameter.
1997-99 Expeditions are equipped with 12mm diameter wheel studs, whereas 2000-2002 models have 14mm studs.
