High Flow Cats on a 3rd Gen
Bojo
Rockford, IL
Anyone here running high flow cats on their 3rd gen?
What are you guys with modified exhaust running?
toms89
technical advisor
MD
My guess is you will be the 1st if you do it to be running them on a 3rd generation. I am the only one here as far as I know who bothered installing high flow cats at all but I am 1st generation. Most just remove the 2nd cats and a few have just eliminated them completely.
Just based on my observation here....
Newport News, VA
checkout knautial2001...he may be running high flows...most that i've heard are running flowmaster exhaust...but there are a few that run others like gibson...borla...spintech...and others....
he may be the 1st...not sure...but i do know youre not the only one running high flows...and not for 1st gens...
do a search for high flow...converter...and anything else you can think of along those lines because its out there....part numbers and all...at least for flowmaster high flows...
toms89
technical advisor
MD
No disrespect Freeway but I was answering the 1st part of Bojo's question. Specifically high flow catalytic converters. Yes many if not most have done exhaust (cat back) with flowmasters mufflers, magnaflow, etc which can be considered high flow but thats not the same as high flow catalytic converters to which I was speaking.
Flowmaster actually does not make or sell catalytic converters.
If any others have installed high flow catalytic converters I would also be interested to know. Its just not the norm. Honestly it would not be beneficial to most expys unless they have some power adder that could benefit with the additional exhaust flow. I assume that is why Bojo is asking.
Newport News, VA
i totally apologize if i came across with an attitude tone...im reading what i typed again and see where it seems that im trying to correct you...not how it is nor how it was sounding in my head...
my bad...my apologies...my fault...sorry for the tone in the post...i truely wasnt trying to be a smart@$$
WHOISMOOTOO
Dallas, TX
+2 if you dont have some extra machinery under the hood putting more air in it might not be worth it unless one of your cats go bad then replace them with high flow? i had 2 cut out and 1 replaced (was bad) and flowmaster 40 put on, sounds pretty good
dmercer3
Leesburg
wondering if I should be doing cat work when I put my new exhaust system on. Putting this on: Magnaflow Exhaust Systems - 16378
So do I need to replace any Cats?
