jruppert
Well I did a plug change today. It really wasnt that bad. I let the air pressure out of front tires and it lowered probably 7 inches or so. Furthest plug in back on passenger side was the hardest to get to but wasnt impossible. Anyway, truck has 226k on it and as far as driveability it ran pretty good but felt sluggish. Gas mileage was around 12 on highway. I replaced the plugs with the OEM Motorcraft. I did not replace the coils. I gapped plugs at .053. Original plugs looked pretty worn out but were gapped around .045. I thought that was rather odd. BTW, ive owned this Expedition for only a couple months. So I replace the plugs and noticed right away that it has a bad miss or hesitation at idle. First start and the engine was shaking quite a bit. I knew there was an issue at that point. I checked for vacuum lines and made sure all harnesses were plugged in. I couldnt find anything. I needed gas so I filled tires up and drove it to the gas station. It had a horrible hesitation at idle to approx 2000 rpm. After that it went completely away. I put gas in it and drove it around. I put around 10 miles on it and never saw a CEL come on. It does appear that the hesitation is improving. Overall rpm band is actually pretty good. It has a lot more pull when kicking it down into lower gear. Pulls a lot better at 55 as well. So what gives? Anyone have any thoughts? My theory is that when I had the fuel rails off maybe some dirt or something dropped into the intake and injector is being funny. Like I said, the hesitation is improving but I can still feel it. When sitting at idle you cant even feel it. Its only when you hit the throttle to take off. Any thoughts? Also, I found this line connected to my brake lines today while working on it. It has no end to it, as if its broken. Anyone know where this may go or suppose to go. Thanks
