samrider777
Do you think I'm able to put 20x12 fuel octane on 305-50-20 toyo AT with 3'' of lift? the tires have really 31.9''x12'' and the wheels -44 offset.
OK
20x12 with -44 offset. You're joking right? If not, I'd say no way, unless you lift it a LOT higher than 3" and plan on cutting up your front fenders.Do you think I'm able to put 20x12 fuel octane on 305-50-20 toyo AT with 3'' of lift? the tires have really 31.9''x12'' and the wheels -44 offset.
well i have a 2nd gen, with 22's and 305/40/22's... in sig
factory is +44 offset.. being -44 offset, he would need to cut the body and bumper, as the sucker wont turn... he would need about a +40 to +35 to run that size wheel
He could probably do it with 10 or 15 inches of liftLifted or not, the offset is going to kill the idea. You are basically moving the tire/rim by approximately 3 inches side to side going from a +44 to a -44 mm offset. Tires can work on a correct offset rim as ZombieSoldier initially told you.
