keyless entry
G
Guest
Guest
I bought a 2001 Expy, and they did not have a keyless entry remote for it, but the salesman I bought it from gave me a new remote and told me I would have to pay to get it installed. Is there any way I can do this myself???....It is just a basic remote, lock, unlock, and panic buttons.........Thanks for any and all help
G
Guest
Guest
There is a way to do it. I can't recall the exact way. I am travleing and the instructions are at home, but its something like turn the key from off to on (not crank starter) 8 times in 10 seconds. It's supposed to throw the power locks, then push the lock button on the remote. Not sure if that is exactly it...but something like that. Maybe do a search of some of the F150 forums.
G
Guest
Guest
To program the transmitters yourself:
Insert a key in the ignition and turn from 3(Off) to 4(On) eight times in rapid succession (within 10 seconds) with the eighth turn ending in the 4(On) position.
The doors will lock/unlock to confirm that programming mode has been entered.
Within 20 seconds, program a remote transmitter by pressing any button on a transmitter. The doors will lock/unlock to confirm that the remote transmitter has been programmed. (If more than 20 seconds pass before pressing a remote transmitter button, the programming mode will exit and the procedure will have to be repeated.)
Repeat the previous step to program additional remote transmitters. The doors will lock/unlock to confirm that each remote transmitter has been programmed.
When you have completed programming the remote transmitters, turn th ignition to 3(Off) or wait 20 seconds. Again the doors will lock/unlock to confirm programming has been completed
