Rear driveshaft's centering ball 4WD Expy
hrashad
Mexico
Hello guys, I have a problem with the drive shaft (rear) of my Ford Expedition 4.6L 4WD. It is overall ok but the centering ball is loose and it is clicking by know (I already disassembly the shaft and see this part damage), I’m afraid it can get worse. I went to several “boneyards” but I can’t find a shaft like this. I found a new one for 400 dlls in cardone but I only need a small component of the shaft, the centering ball assembly (you know the one that is inside the nut next to the transmission). The attached file is a JPG of the shaft
H
hrashad
Mexico
The part is inside the center yoke which has 2 U-joints. It has a centering ball. If you see the top item shown in the pic it has 4 bolts.
A used shaft would be helpful too
H
hrashad
Mexico
