Dashboard dimmer switch question
murmaider2
Brooklyn, NY
Hello everyone!
I'm new to this forum, and two weeks since an owner of a 2001 Expedition Eddie Bauer 5.4.
I'm not sure if I'm simply not using it right, or there is an issue with it, but the little roll switch that dims the backlights for the entire dashboard has been giving me some issues. None of the interior lights work unless the switch is rolled all the way up until it clicks into place, however when it is in that position, the courtesy lights on the door panels and on the running boards do not want to turn off even if you turn off the engine and lock the car.
All help is greatly appreciated, thank you!
barigyasi
Alabama
I'm pretty sure it is wired that way, i could be wrong, but when you move that roller all the way up and it clicks, that turns on all the inside lights, including the door panel lights, and it would stay on until you turn them back down by rolling it back to the off position.
Edit:
Do you map lights come on without the switch being on?
I do have an XLT so it might be different
M
murmaider2
Brooklyn, NY
Edit:
Without the dimmer being in the all the way up and clicked position, none of the interior lights will work. The switches for the map lights simply don't do anything. When you roll the dimmer all the way up, only then the switches for the map lights turn them on and off. They don't respond to the doors opening or closing either.
Another question that should be asked is do you have a constant door ajar light on?
I do not, funnily enough that only blinks on sometimes when you accelerate hard.
barigyasi
Alabama
ahh okay, well I have no idea what it could be man, sorry! hopefully someone else will have some more tips!
FordandPolaris
Saint Cloud, MN
I would start by WD-40'ing each door latch and see if that helps. I used to have a sensor that was sticking, giving the door ajar quite often.
Myfender
usa
I have the same exact issue in my 2011. Expedition did you ever get this resolved?
1955moose
Just tried mine, I have one year older Eddie. Mine brings up the brightness on radio and dash, right before it pops on back some lights above rear doors. Check all your fuses not only for continuity, but power on both sides of fuse. You may have a bad switch.
Myfender
usa
they work when the doors open and remote unlock but to push button to turn on light on and off you have to move the dash dimmer switch to full bright. I will double check the fuses, seemed to start after replacing build with led, probably need to go back to standard bulb
1955moose
A friend of mine is having weird problems with first generation mercury cougar, after led replacements. Don't know if the two are connected but it's easy enough to switch back. When you have dimmer switch exposed, check continuity while moving switch towards brighter setting. It should increase as you move it, if operating proper. Also check power and ground at plug going to switch. Keep us posted
