Removing face plate aorund radio - 2007
chevy24d
Orange, CT
Can anyone tell me how to remove the dash cover around the radio and heater controls? I was hoping it was held with simple spring clips that you just push the cover to engage, but I do not want to find out the hard way!
Why you ask - I was going to hard wire a backup camera and I want to drill a hole thru this panel to run the wires neatly behind the dash. I want to see what is back there and drill it on the bench.
Thanks for any insight
Mark
mustangswan
seattle
The shop manual says the it is just held on by clips. It also says to remove the center lower panel before the upper center panel around the radio.
tk1971
LA, CA
I just stick my finger in the cig lighter and start pulling. I have an 07 (BTW), and the clip in that area comes off first. Then using a plastic screwdriver the rest of the clips can be popped off. Good luck.
tk
C
chevy24d
Orange, CT
Originally posted by tk1971
I just stick my finger in the cig lighter and start pulling. I have an 07 (BTW), and the clip in that area comes off first. Then using a plastic screwdriver the rest of the clips can be popped off. Good luck.tk
Thanks - Can I assume that you did this already?
Another question - I plugged my cell phone charger into the Cig lighter to no avail. Are these hard to get a good connection?
tk1971
LA, CA
Yep. Did it several times to install my Parrot Bluetooth and other stuff. Like the last poster said, it is live all the time. I wired my VR3 monitor to the cig power and then realized it didn't go off at all and had to take it apart again, and again, and again (for other reasons).
C
chevy24d
Orange, CT
Thanks - forgot to ask you - do you really have to pull the lower panel first before sticking my finger in the cig lighter?
BTW - my cig problem was a blown fuse under the hood....
tk1971
LA, CA
I did pull the lower panel out the first time, but after that, I found that I didn't have to.
tk
tk1971
LA, CA
That's exactly how I did it. That corner should pop right out. Once you get a corner out, you can stick whatever implement (finger, if it fits) in there and pry the rest of the clips off. The plastic does feel thin, but it is rather flexible. Good luck.
tk
C
chevy24d
Orange, CT
Backup Camera Installation complete
I just finished the install of my backup camera. I ended up wiring the camera to the reverse light circuit at the trailer hitch wiring. The monitor is wired to the reverse light circuit that is in the passenger kick panel wiring. The reverse light wire is green/brown. I ended up combining the two power wires together so when I go into reverese, the power on the unit comes on, along with the trigger wire.
I mounted the monitor to the switch blanks on the console over the radio and ran the wires thru this same blank on the face of the console as shown in the pics.
http://s254.photobucket.com/albums/hh92/boatrboy/Expedition - 2007/?action=view&current=IMG_1780.jpg
http://s254.photobucket.com/albums/hh92/boatrboy/Expedition - 2007/?action=view&current=IMG_1778.jpg
http://s254.photobucket.com/albums/hh92/boatrboy/Expedition - 2007/?action=view&current=IMG_1779.jpg
http://s254.photobucket.com/albums/hh92/boatrboy/Expedition - 2007/?action=view&current=IMG_1776.jpg
