Assistance Needed: Lt & Rt Kick Panel Removal
CertusExpo
Customizing trucks since I was 7 with my Legos
Fort Worth, TX
I need to A. Tap into existing wire that feeds the courtesy light on the mirrors and B. Run wiring for an LED lightbar so...
HOW THE HECK do I get the kick panels off??!
BTW, does anyone KNOW which wire powers the courtesy lamps in the mirrors?
Bedrck47
Elizebethtown, PA
it always helps to know year, model and engine information
Update your signature line with year model and engine information. This can be done in the USER CP section as this information helps others give you replies specific to your vehicle.
Bedrck47
Elizebethtown, PA
which mirrors are you referring to Inside or outside??
Can you read and understand wiring diagrams
CertusExpo
CertusExpo
Fort Worth, TX
Good point, thank you.
2003 2WD EB 5.4 Expo
CertusExpo
CertusExpo
Fort Worth, TX
I am referring to the courtesy lights on the outside mirrors. I need to tap into the wire that is fed power when using the keyless entry and the interior/exterior courtesy lights all come on.
Yes, I can understand them but cannot find one.
Bedrck47
Elizebethtown, PA
to remove the kick panels just remove the weather strip that comes down the a pillar and the door kick plate pull the carpet back a little and the kick panel should pull out towards the rear Check to see if there are any screws that need to be removed Am not a 100% sure about the 03 but that is how the 1st gens are done
  • 89-01.pdf
  • 89-02.pdf
  • 89-03.pdf
  • 89-04.pdf
  • 89-05.pdf
CertusExpo
CertusExpo
Fort Worth, TX
THANK YOU FOR THESE!!
I look forward to those mods and will post pics.
Bedrck47
Elizebethtown, PA
the best place for you to tap into a wire would be on the drivers side I will try to send you a copy of the connector you need to use and the wire color Use a test light to make sure this is the circuit you need before making any mods to the wire
Bedrck47
Elizebethtown, PA
you want the black/light blue wire which is pin 59 of connector C239
  • 150-29.pdf
  • 151-19.pdf
