rtbrjason
I'll look at the wiring diagram later tonight to find the color code for the sense wire. As a test it would be interesting to see if a straight shot from the battery to the sense and another to alt case ground has an effect on the wave form.
A good wave form looks like continuous string of lower case "m".
It would also help to know the high and low voltage reading on the scope. Even though a dmm shows 14.3 volts it may not respond fast enough for the spike to register.
I never really got anywhere with this and am still having this issue.
It does appear to be an alternator issue. With the alternator disconnected from the battery, the flickering goes away. As soon as I touch the alternator main wire to the battery +, it starts flickering.
Not sure what else to do since all 3 alternators have had this behavior and all signs point to it being the alternator.
I do have a ridiculously oversized ground running from the alternator straight to battery. The rest of the "Big 4" grounds are also done. I tried with an without a secondary 0 awg charge wire from the alternator. I replaced the short run of the other 2 wires that run to the alternator as well.
