vigman
Going to put this in the mix as well.. the ALT bolts to the block I ASSUME that connection was wire wheeled ( or other method ) cleaned ? Are the batt terminals OE or aftermarket ?
I agree. I had a Lincoln Mark 7 that charged fine till you loaded it with lights,heater, radio, then charging dropped. On Ford cars and trucks they need proper amperage and voltage. Best advice , see if you can buy new alternator not remanufactured. Works the best. Reman alternators and starters have cheap parts from China. They fail or give weird symptoms constantly. For what it's worth like your Daddy said you gets what you pay for.
When you can, check the battery with a dmm set on a/c volts and take a reading, let us know what it is please. At idle and any higher rpm.
Spent some time digging through the books looking for other possibilities that will cause a flicker other than the alternator. Everything comes back as varying voltage causing the flicker - the alternator is the culprit. The only real way to determine if that is the case is to look at the alternators output wave form on an oscilloscope while in the vehicle.
What shape did the wave form have? Normal is a continuous series of humps, all being the same in height and the same length.
When you ran new wire did you completely replace the old wire? Specifically the sense wire from the voltage reg to the battery?
