northernexp
I got the oil pan back on today with a fresh new gasket, I cleaned the mating surfaces and the entire pan inside and out, then hit it with a coat of high temp paint, some of the original paint was disappearing around the drain hole and I wanted to coat it before rust starts.
Also drained the transmission, dropped the pan and changed out the filter. The pan was stamped letting me know that the gasket was re usable. Normally I would have changed it anyways but the gasket that came with the ATP kit was a paper gasket compared to the oem rubber with steel gasket, and the oem gasket wasn't leaking so I cleaned it up and re installed the pan.
I hit both pan flanges with permatex high tack liquid gasket, it really holds onto the gaskets well and adds a little extra insurance against leaking, I don't use it on the block or transmission.
I did however use permatex high heat gasket sealer at each corner of the block where seams are.
I drained and filled the front diff and the transfer case, I did the rear diff a year ago and only drove for 5 months on it so it should be good still.
I went ahead and changed the serpentine belt and the fuel filter, finishing off my maintenance list.
I haven't added oil yet, I'm waiting until the gasket sealer has 24 hours to fully cure before I let oil touch it, I'm really looking forward to going for a drive tomorrow!!efb70a06c9e1cc5274f2e90ba8c142fe.jpg
Sent from my SGH-I337M using Tapatalk
Maverick1701
Memphis, TX
Did a little towing today. The whole trip was around 6-7hr (3hr there 3-ish hr back). I bought a parts Jeep. The plan is for this jeep to heroically sacrifice its life so that my Jeep can live.
The exped performed flawlessly as usual. I did notice a little idle funky-ness which I have to investigate. I had new tires installed last week and they worked extremely well. No complaints. I think they are 245/70R17 (that is going off the top of my head...so don't quote me on that).
northernexp
Did the oil filter adaptor gasket today, done with my maintenance!
GaryH2
SE PA
I got the rear hatch repainted (see pic before repair), then took it to MA and back last weekend. From what I read, I got a really good price on the work. Although the paint was bubbling below the rear window, the shop said it was coming off above the window as well. Looks like new now!
Also, apparently the drivers side rear door started collecting a bunch of water over the past couple days so I empties that out this weekend too.
Flexpedition
midwest
Bought a clear bug shield, taped off the front and painted the back. Couple coats of Ford Colorado red. Then a coat or two white to make the red pop. Then several coats of black. Sunlight doesn't penetrate it at all, and when you look down the hood, all you see is the black. Pretty happy overall, although its not as wide as the smoked bugshield it is replacing.
Wade/Westin brand, about $54 on Amazon, which includes shipping for Prime members.
Amazon.com: Wade 72-96143 Clear Platinum Bug Shield: Automotive
I think I might try painting the sunroof deflector gloss black. Nobody makes them in clear, and I'm tired of the smoked look.
northernexp
Installed an led light bar! It's only a 12" cree light bar since I'm on a budget, and it was only 70$.
cman1120
Looks good! Any output shots of the light?
Sent from my SAMSUNG-SGH-I747 using Tapatalk
northernexp
Thanks! No I haven't had a chance to aim the light yet, iv actually might just bite the bullet and exchange this light for the 20" model today.
northernexp
It took some persuasion but I got the guy at the warehouse to exchange the 12" for the 20" light bar and I paid the difference. It looks much more appropriate on the expedition given how big the front bumper is.
Pics of it installed in a couple hours and pics of the light output tonight! I'm expecting good things since the 12" was already bright as hell.
The beam is a spot/flood combo, with the spot beam in the center and the flood beam on the left and right sides. You can easily notice the difference by looking at the lights, the spot beam has a smooth reflector surface and the flood reflectors have a stepped design.
cman1120
Awesome! More light is never a bad thing at all.
northernexp
Yes definitely!! Because this light bar is 126 watts, do I have to wire it with both left and right fog light wires?
k9education
You can trigger it with one of the fogs via relay, but it should be wired directly to the battery or a power block for power. Getting power through the fogs is almost certain to fry the stock wiring. Heck, the stock wiring isn't even a large enough gauge to support most aftermarket incandescent fogs.
northernexp
Thanks, that's what I'll do. I spoke to an hid store that's local and they have the exact wiring kit I need. I wired it temporarily just to see the lights on for a minute and they look great.
I think the 20" light bar looks more appropriate than the 12".
k9education
Today I finally started on the installation of the backup light kit I purchased over the summer. Rather than dismantle the harness, cut a huge hole in the firewall, or cut a huge slit in the existing firewall grommet, I decided to mount the relay in the engine compartment. Although I really have no concerns over it getting wet where it is, I modified a small project box to house it. For tonight, I Ziploc'd the wiring, stuffed it up in the fender, and moved on to running the wires to the rear.
F**k me, what a ***** that job was. I wanted to run the wires right alongside the stock harness, which is a real pain in the ass as you get towards the rear of the vehicle. Ultimately, I removed the spare tire, which made running the last few feet 100x easier. The hardest part was actually zip tying the whole thing to the stock wiring. At some points, you can't see at all and you can only (just barely) get one hand up to the wiring. Anyway, once that was done I bagged the ends of those wires as well and tucked them up in the bumper for tonight. Hopefully I'll have time to finish this project later this week.
northernexp
Backup lights are so handy, and they also help when you're on the highway and the person behind you has their high beams on, a good couple flashes from backup lights usually wake the person up lol.
nsperf
Akron Ohio
I just added 4 mastercraft mxt 265/75 16 tires and drivers side front wheel bearing.
drives nice now. cant wait for winter.
wermad
SoCal
Finally replaced the worn to the bone old tires that came w/ my new wheels. Wheels are used concept neepers wrapped in inexpensive safiros (same tires that came w/ the 20s when I bought my lim, no complaints and so i went with them). Ride is a bit harder but wife and I are used to it having had a Mazda 6 wagon w/ low profile 18s for six years.
LL
CrimsonKing
Nothing fancy, just added a set of inexpensive offroad lights.
northernexp
I wired up the light bar via a relay using one side of the oem wiring as the trigger, thanks k9 education for the tips, is much appreciated. I also decided to move the light bar into the lower center part of the bumper.
My family and I are packing up and moving east in 3 weeks, I'm a born and raised prairie boy so I'm a bit nervous I've lived in the same city my entire life but my wife has a great businesses opportunity so we are taking the plunge, where we're relocating front license plates are not mandatory so I made the change now so I don't have to do so in the middle of winter with no garage until our new home is built.
