Your nuts if you think the factory sub amp...
johnboneske
Doesn't have any power! I was wiring in my adapter today so I can run either the factory DVC sub, or a single 10" DVC (dual 4 ohm)I have in a sealed 1.2 cuft3 box I have...
So screwing around I took my Kicker Comp 12's (4 ohm each) I have in a sealed box at 1.65cuft3 per side and wired it up to see if the factory amp has any power? Holy cow does it!!
I can make the mirror vibrate it's ass off and has plenty of power. Now I was just screwing around and put my 10 back in it...
I am NOT saying I wasn't making any THD driving it harder than the factory said it should be driven, but it works great!
BTW, I have a Sony aftermarket Head unit with sub outs, so I can adjust the level of the sub output.
johnboneske
johnboneske
BTW, my 10" DVC sub is an older Infinity Reference Beta I had laying around... and works great in the truck with just the factory amp.
Hampton, VA
ur mirror may shake cuz it doesn't take much...but its a 100 watt amp...so it will move the sub...definitely not to full capability...I will say though...you are the ONLY ONE of the many that have changed their sub to give such a review...lol
Lostneye
NY
Moving to 2 12"s or even a 10" will move quite a bit more air than a single 8". But 100W is not that powerful. If you are happy with it that's great and saves you money for another amp. I can shake my mirror with more power and a Polk 8" in the factory box but I still want more. I will be upgrading to at least one 12" and more power.
johnboneske
johnboneske
I don't do agree with you. But I assumed by reading all I have read on here it isn't enough power.(I would beg to differ)
But do you know the difference between 100 and 500 watts? Less than 7db. So a sub that has an efficiency of 93 or 94 dB @ 1w1m is "louder" than a sub with a 85 or 86 dB sensitivity.
I do plan on building (fiberglassing) a new box in the spring to hold my 10 in the factory location. I will update all of you on how my success goes-there is PLENTY of room to get 1.1cuft3 or more in there.
johnboneske
johnboneske
If you get a sub from someone like parts express with a longer Xmas a 10 will be as good as a 12.
Lostneye
NY
I think the consensus is if you're doing the work it's worth the upgrade. Audio is subjective. Some people are plenty happy with the stock system. I am past the days of setting off car alarms with my system but want more than the THX system in my Navi can give.
7db is actually about 5 times as loud and will "sound" almost twice as loud to the human ear. Sound is exponential not linear and the human ear isn't that good with small changes in amplitude.
You are correct but as far as driver sensitivity however that's only one measurement. Different driver's behave differently and are affected by the enclosure they are in(size, sealed/ported) and the size of the interior and placement in the vehicle will all affect how it will sound. In general a higher sensitivity will be louder but other factors will affect it as well, including how much power the driver is getting.
Just like sensitivity Xmas is only one measurement. On paper it may seem to translate well but in the real world it can be very different. The Thiele Small parameters are to be used a as a whole to aid in box design. While picking individual specs out can sometimes be helpful it doesn't tell the whole story.
Hampton, VA
its all in the enclosure...the factory enclosure is sealed...I use vented/ported...I haven't dealt with anything less than 1500 rms in years...100 watts will shake the mirror so I'm not moved by that...at the end of the day...if ur happy ur good...u have plans on moving up in size...right now I 5 amps...and none are less than 6k rms...2-4500 rms...1-3500 rms...3-3000 rms...I want ppl to hear me before they see me...lol
johnboneske
johnboneske
Just an fyi... you can do it withis alot less power than that! I used to compete back in the day in IASCA and had 2 Orion HCCA 225's... one on the subs (4) 12's and one on front /rear and it would beat your ass... and later on with a Soundstream reference 404 on front/rear, and a reference 700 on the subs. but that was in a 79 Pontiac Bonneville 2dr... I did db drags once and ran 138.4db... it whooped ass!!
Lostneye
NY
You're crazy if you think I'm going to believe those Orions only put out 100W
But you have a point there was a time when most name brand amps were underrated and bulletproof. Now it is completely opposite and going with big names doesn't mean you will get quality gear.
