Hello everybody,
Not sure were to post this question. Before I PCS'd to Italy I decided to covert the Expy to HID (low, highs and the driving lights). I only had time to do the low's and driving light before I had to ship the Expy. Once here I finally had time to install the high beams, the install went smooth as it did before. Here is the problem, after I installed the hight beams I noticed that the hi beam indicator on the instrument cluster had a slight glow to it. Also most of the time the driving lights will not come back on when you use the high beams. I have to manually turn them off and back on for then to turn back on. I thought when you have a slight glow on one of your lights indicator in the cluster (blinkers and lights) it meant that that light has a bad bulb. Do the HID's draw less voltage that makes the Expy think that the bulb is bad?
One more thing, I would like to do the hi-beam and driving lights mod. Where the driving lights stay on even when you turn on your hi beams, has any one done this mod on an 03 and higher. Instructions would be appreciated.
Here are a few pics of the HID's;
the kit
lows nad driving lights
high beams
hi beam indicator
hi beams on
Any info would be great. Thanks in advance.
AF
the kit
high beams
hi beam indicator
hi beams on
AF
