dieselwrench1
Hello, I am new here and trying to find some answers as searching online got me nowhere and youtube was the same, the problem I have with my expedition is the brakes feel spongy, like they have air, I just replaced the front rotors and brake pads due to the right side rotor was wearing out on the top portion of the rotor, when I took it apart, I found that the outer pad was worn out and damage the rotor but the inner pad was ok and still had life in it, the left side was similar but not like the right side, I put it all together and went around the block, the brakes were spongy, and felt like they were sticking and did not feel right, even when braking at low speeds I could feel that it is not braking right, when I got back I rechecked the brakes and found that both sides are only braking on the top part of the rotor, can anyone help out on this and what is the possible problem? tomorrow I will check the calipers to see if they have something stuck and causing this. or any suggestions as to what to look for would really be appreciated!!
