Keep us posted on this I gotta it myself lolDear rusted out radiator support: you suck!View attachment 17614
Looks clean bro... What's the tpms training tool?
Ah I have never even looked into these... Figured just switching over my tpms sensors to my 35s would be good. The tire shop said something about programming them but I'm not sure I was listening I was too busy drooling over my tires lolIts to program (aka "train") the sensors. Its about $35 and the procedure is simple. I already had it when i switched to 24s from the stock 20s. I got lucky my 24's came off a navi that retained the stock sensors. Unfortunately, the band was at its max and I could not use it for the 26s I got today. The shop did have the new belts and they were inexpensive ~$15 each but labor was double due to swapping sensors from one wheel to another. Still, it was cheaper then having new sensors put in and I'm sure I would not get that cost back when it comes time to sell the 24s had i gotten new sensors.
Since the 26s use a different pressure, my TPMS warning came on. By training them with the tool, it tells the system the new nominal pressure for this new wheel/tire package.
I'll have to double check if this is the correct p/n. Btw, if your Expy has no tpms, then its not needed if you change your tires or wheels or both.
Wow if mine tries to do that to me were gonna have a problem lol...... Btw still haven't even driven it in over 2 weeks (expect back and forth to the fire shop in limo mode lol)Lol, yeah that's what you have to do. The shop I went to wanted $60, but I told them I already had the tool. I believe if you have two og keys and fobs, you don't need the tool. Otherwise, its not terribly expensive to have around in case something changes with your tire setup. From experience, my 07 limited (no pun intended) me to 4k rpm and was very nasty at cutting power under hard acceleration until I got rid of the TPMS warning.
Worked on a new center dash panel. Got a 2nd one and starts chopping it up. Did the fiberglass work on it. It's going well!
Huh I just read your post and googled what's a center cap locks are, I'm wondering how they install if the cap is clip on and the wheel doesn't have any holes for a screw to go into
If u really want rim security...go to rimlox.com...true security...any other wheel lock can be broke off...and they guarantee security or they will buy u new rims
Mr. 10K
