A/C or heat only blows through the defrost vents on 2005 Eddie Bauer
z400pilot
Utah
A few years ago I had the same problem and I search this forum. I checked the vacuum lines between the battery and the firewall and found one broken. I fixed it with a piece of vacuum line and all worked well. It was the bottom of the t-fitting and went towards the back of the engine & firewall along the passenger side of the valve cover.
Last weekend I replaced my timing chains, guides, tensioners, cam phasers, solenoids, lower timing chain sprocket, and upgraded the oil pump. I had to disconnect the A/C lines that run over the passenger valve cover so I replaced all of the o-rings in the A/C lines under the hood area. After starting the car everything ran smoothly. I turned on the fan to have some airflow in the car and the air defaulted out of the defrost vents again, regardless of which setting I picked.
Looking under the hood I discovered that the vacuum line between the battery and the firewall had broken again during all of the work removing the powertrain module for my timing component replacements. I removed the broken vacuum line from the bottom of the t-fitting to where it enters a convoluted plastic covering along with another vacuum line and replaced it with rubber vacuum line. I thought my problem would be fixed.
I fixed the vacuum leaking sound but the vents are still only blowing out of the defrost. I've inspected all the lines and they all seem to be good. The only questionable fitting is where the hard plastic line leaves the t-fitting and goes behind the battery box and connects to the vacuum reservoir. The rubber connection at that point seems a little soft, so I will pick up some vacuum line this week and replace it from the t-fitting to the vacuum reservoir behind the battery box. If that isn't it, I'm not sure where to go. The vacuum line that comes out of the bottom of the t-fitting is the one that has broken twice. It runs along the passenger valve cover and disappears behind the engine and firewall so tracing it all the way back wouldn't be easy.
Does anyone have any suggestions?
1955moose
You've lost vacuum to the hvac controls. Somehow when you were working on it you crimped a line or broke one of the fittings. Are you getting a rough idle? Or is it just the blender doors acting up. If the hoses are old and brittle, I'd get a bunch of new hose and fittings, metal if you can find them. When working on customers cars that had brittle vacuum hoses with intake leaks, I'd replace all with new. If one fails, the others are right behind it. I'd start on all the hoses where you were working. Also a trick that sometimes works is cycling the key on and off about 5 times. Works on Gm cars, might work on ford.
Bedrck47
Elizebethtown, PA
Welcome to the Forum Repair the vacuum lines that's most likely your problem Would also suggest that get a copy of the ford service manual
Z
z400pilot
Utah
I'm not getting a rough idle, but it does seem just a little lower than before. I plan on replacing some more lines, but the 2 that I need to seem to disappear behind the engine.
Z
z400pilot
Utah
I'll have to think about getting one, I have been making due with a Haynes manual for years. I only plan on keeping this vehicle about 3-4 more years.
1955moose
If their real difficult like most things are on these SUVs spray them along their route. See if anything changed like idle or heat controls changing. If so and you can't get at them, see if you can repair. My guess is it's one of the ones near where you were working.
1955moose
I like wd 40, but carb or electrical spray works. Usually when you hit bad hose or gasket car idle smooths out, or in your case maybe blender door works. When checking vacuum leaks and you hit right spot spray comes out back of Exaust. Spray small amounts, concentrate on smaller areas. It can be time consuming but worth it, when you find problem.
