04 expy cruise control not working
keithnra
jax, fl
Heres what i have changed, checked etc
1. Replaced cable from cruise box to throttle body, the cable was broken
2. Checked for power at cruise box
3. I remember the cruise working before i changed the throttle body due to rough idle. I broke the clipn on cable is why it was replaced.
Nothing comes on on steering wheel.when u press on for cruise.
K
keithnra
jax, fl
Ive also checked all the fuses in the passenger side, are there any fuses under the hood
K
keithnra
jax, fl
Well today i went to junkyard and gotna cruise control servo ass. And it still doesnt work. I at a loss
Bedrck47
Elizebethtown, PA
I would love to answer you but being you didn't bother to answer the first question I asked (posted) I won't ask anymore.
K
keithnra
jax, fl
I did tey and respond from my phone and it didnt go thru i guess, i checked them with a test light
Bedrck47
Elizebethtown, PA
OK Now Your Signature line says a 2001 expy But the thread is for a 2004 expy. So I take it you want information on the 04
Did you run the cruise control self test??
K
keithnra
jax, fl
I ran it and there was 3 blinks at the end, so.thats.why i.vought a cruise.servo..maybe it.was bad
Bedrck47
Elizebethtown, PA
The following is from the 04 Ford service manual
2 Flashes BPP defective, circuit is defective, brake applied
3 Flashes Deactivator switch is open or circuit defective
Check the deactivator switch
Bedrck47
Elizebethtown, PA
Its a back up to the Brake Pedal Switch
Its is located just to the left of the brake pedal
There are two wires for the switch a Red/White and a Black/Yellow wire at the connector for the switch
The switch is a normally closed switch To test the switch you could put a jumper between the two wires and then try your speed control.
See attached print
Bedrck47
Elizebethtown, PA
Speed Control
The speed control system consists of the following components:
  • brake pedal position (BPP) switch
  • deactivator switch
  • speed control actuator
  • speed control actuator cable
  • speed control actuator switches
  • powertrain control module (PCM)
Principles of Operation
The speed control system is designed to maintain a selected vehicle speed between approximately 40 and 200 km/h (25 and 125 mph).
The electronic stepper motor (internal to the speed control actuator) is controlled by turning the three phases of the motor on and off in sequence. The sequence determines the motor direction (open throttle or closed throttle based on vehicle speed).
The speed control module is fully integrated into the powertrain control module (PCM). The PCM strategy uses engine control to accelerate smoothly. In instances where the vehicle tends to want to exceed the set speed, the PCM will invoke an engine braking strategy to help maintain the desired vehicle speed.
Whenever the system is engaged and active, a speed control set indicator will be illuminated in the instrument cluster.
The brake pedal position (BPP) switch is a normally open switch. When the brake pedal is applied with the speed control system engaged, the BPP switch closes to battery voltage, putting the vehicle speed control in stand-by mode.
NOTE: The deactivator switch is provided as an additional safety feature.
Normally, when the brake pedal is pressed, the PCM will deactivate the speed control system. Under increased brake pedal effort, the deactivator switch, a normally closed switch, will open and remove power to the speed control actuator clutch, releasing the throttle independently of the PCM.
The clockspring provides the electrical interface between the steering column wiring and the speed control switches in the steering wheel.
The PCM sends a standard corporate protocol (SCP) output message to the instrument cluster to indicate when the vehicle speed control system is active.
K
keithnra
jax, fl
Thanks guys im fgonna take a stab at it this afternoon, really miss cruise
