2004 Expedition No Fan Speed Adjustment In Front
tnorris1531
Niantic, CT
I have a 2004 Expedition and while on vacation my climate control module in the dash flickered for a day then went dead. I ordered a replacement on Ebay and now the rear climate control works (all fan settings as well as heat and A/C) but in the front I have no fan control and cannot hear any dampers switching position (for instance from floor setting to dash vent setting changes). If I put the A/C button on it lights up and I can feel a faint blowing from the defrost and by my feet but VERY faint. Any thoughts as to what this could be?
T
tnorris1531
Niantic, CT
Thanks, super happy to find this forum! I have automatic controls with dual climate control for driver and passenger. However nothing works up front. Even if I put it in Auto it doesnt change the fan speed at all.
Bedrck47
Elizebethtown, PA
Have you checked fuses and if so how did you check them and which fuses did you check Fuse # please
T
tnorris1531
Niantic, CT
I actually have pulled all the fuses in search of the issue. None were visibly damaged (I work as a marine electrician so I know what a bad fuse looks like) I also replaced the relay just in case and still nothing.
Bedrck47
Elizebethtown, PA
you may be a marine electrician and I don't doubt that. And the fuses may look good and not blown But answer this. Could you see the voltage flowing thru the fuse? Or did you test for voltage into and out of the fuse
The thing about working on these expeditions is looks can be deceiving. If a vehicle doesn't start would you just look at the battery and say it looks good or would you test it.
The EATC system works on voltage. You could have 20 known and tested good fuses hooked in series but if you don't have the 12 volts you have a dead circuit.
T
tnorris1531
Niantic, CT
I checked the voltage coming in and leaving the fuse box and it was good. I will run the diagnostics on the EATC and see what the codes come back as.
Bedrck47
Elizebethtown, PA
when you checked the fuses was the key in the ignition and was the engine running or was the key out
T
tnorris1531
Niantic, CT
I checked the EATC for codes and it checked out ok (all 8's). I replaced the fan relay today and still nothing. I have read about some EATC's needing to be programmed by a dealer after they are replaced is that the case with an 04 Ex? I replaced it since it was completely dead and now the rear blower and air work great but nothing from the front. I have tried connecting a new blower motor as well and still nothing.
Bedrck47
Elizebethtown, PA
Any updates of what happened???
Do you really expect an update The OP's last post was about 6 months ago. He hasn't bothered to post any update since. And he hasn't been on the forum since Aug 2016 This is very typical of new members.
If you are having a problem I would suggest that you start a new thread concerning your problem
