Power window switch replacement
06EXP
Charleston, SC
Anybody know how to get to the power window switch on the passenger front door. The window will roll down but not up using the switch on the passenger side door. But it will work normally with the driver side swith. I'm thinking a loose wire or a bad switch, I can't seem to see how to get to it.
Thanks for the help!
ELVATO
Orlando, FL
Grab the trim piece that surrounds the switch and pull up.
Sorry, you have to pull the dark brown trim that surround the door handle first.
Here's a vid. :)
http://blip.tv/file/3252402
06EXP
Charleston, SC
Here's a vid. :)
Sweet!! Looks really easy. Just from me looking at it I thought the trim that is around the switches was molded into the entire door panel. Thanks for the vid!:):D:)
06EXP
Charleston, SC
Also, if it is the switch that is bad. What years of the Expy are the switches the same, I'm planning on getting one from the salvage yard. Mine is 06.
ELVATO
Orlando, FL
03-06.
Not sure if you can snap one of the previous model in there. Have you tried openeing the switch itself and cleaning the contacts?
The video is about the LEDs in the switch not lighting up, so I maybe talking about that, not sure, but essentially, it'll show you how to take apart the maser switch. The passenger one should be similar. You should be able to clean the contacts without taking off the PCB board.
http://blip.tv/file/3015848
06EXP
Charleston, SC
Am going to try to clean the contacts this evening, but just wanted to know what I could look for IF I have to buy a switch. Thanks alot ELEVATO!!
06EXP
Charleston, SC
Alright.....I got the trim off and unplugged the switch and cleaned the contacts and now the switch will roll the window up about 1 out of 2 times. It will roll down every time you push the down button but you have to push the up button twice or sometimes three times to get it to go back up. So I might call around the local salvage yards to see if I can find a switch that works. Thanks alot Elevato for the vids!!
BLKSVT
League City, TEXAS
I have the same issues in my 03, the drivers side front window switch works 1/2 the damn time. I'm just gonna replace it, I already tried cleaning it and that worked for a day or so...now the wife is asking what did you do it still doesn't work, thought you fixed it..blah..blah...blah
Doc72
Orlando
There is a mobile power window repair service in Orlando. The owner phone is 407-415-5401 and he always gives me free tips and advice.
Just tell him you are looking for help and he has always been happy to help with questions I give him on all makes and models for free. They also sell a lot of car door products on the internet at powerwindowrepairservices.com
Walk03XLT
Olathe, KS
I've got the same problem with a couple of my switches. Stole the switch out of the pass rear door to put in the pass front so it works for the time being. Driver's switch is hit and miss too. Found quite a few on ebay for around $45-50. Probably just gonna spring for one of those
http://goo.gl/tZ9Eb
There's a bunch of single switches too.
