Rear defroster works but not mirrors..anymore
BaggedExpy
Derby
I had power at both mirrors and defroster.. i was hooking up mirrors and messed up and touched that wire to something.. i thought i popped fuse or relay but both checked out good. I even moved around relays and no mirrors just rear defroster powered... does the switch have two circuits? One for defroster and one for mirrors? I finally got my 04 mirrors hooked up to my stock mirror switch and thats the last thing i need working
BaggedExpy
BaggedExpy
Derby
check these fuses
under dash 4, 6 and 17
under hood 27
if you need the print let me know
I checked 6 and 27 but didnt 4 and 17. I will try those soon as i get back to the shop. Thanks again for helping
Bedrck47
Elizebethtown, PA
Fuse 27 is the main feed for both the heated mirrors and the rear defogger But the circuit splits and the mirrors get their power feed thru fuse 17 a 10 amp fuse
Have attached print
BaggedExpy
BaggedExpy
Derby
Aw sweet. Makes sense now that i see diagram. I was wondering if there was 2 circuits or switch was bad.
sharprd65
