2003 5.4 EB Fuel Pump Relay
CertusExpo
Customizing trucks since I was 7 with my Legos
Fort Worth, TX
Okay...
Yesterday afternoon I went to leave work and found myself in the good cranking but no start scenario. I immediately started processing the possible causes and it came down to ignition or fuel delivery.
I went back up to my office and began researching and found several forum threads from multiple sources that pointed to either the pump itself or the relay. The main issue being my location/distance from home/tools and limited amount of resources on-board as well as availability in downtown Dallas.
I made a trip via train to the nearest auto parts store that was the shortest stop from the train stop and while there, I purchased two cans of starter fluid, electrical tape and a handy 10-foot retractable test lead with alligator clips.
When I got back to my office I began troubleshooting and through process of illumination the issue came down to fuel delivery as the engine would start when spraying the stater fluid into the throttle body. I then went back to my office and searched YouTube for videos on replacement of the fuel pump so I could make a list of needed tools for my son to bring out to perform the pump replacement on-site. I also came across this video.
While watching that video he showed a schematic of the fuel pump relay and he explained which wire on which plug on the fuse box was the hot (14-gauge Green w/ Yellow Stripe) that went to the fuel pump. Then it suddenly hit me. I can unplug it, carefully expose some of wire and using the test lead I purchased, I could validate/invalidate if the failure was the relay or the pump by running power straight to the pump and bypassing the relay.
I took a small paper clamp, removed one of the silver finger tabs and shaped it to fit inside the plug of the DG/YE plug itself. (https://cdnimg.webstaurantstore.com/images/products/medium/234014/1258245.jpg)
Once I had pushed my test clip in I then clipped one of the alligator clips to it and then exposed some of the insulation of the hot lead coming off a cigarette lighter plug from an accessory and clipped the other end of the test lead to it. She cranked and tried momentarily to start but didn't. I then figured that the plug needed to be plugged into the fuse box to complete some kind of circuit for the PCM or ??
I plugged it back into the fuse box with the test lead still attached and gave her a crank.
VAAAROOOOM! SUCCESS!
She idled just fine and I didn't have any fires or explosions :)
I had just verified that the pump was good, the relay was bad AND found a way to get myself home all in one fell swoop.
I burned up two cigarette lighter adapters on the way home due to both the distance from home as well as the amount of voltage being drawn through too small of gauge wire for the adapters but at least I wasn't stuck in the middle of downtown Dallas over-night, didn't have to call a tow or leave her behind and come back to a, most-likely broken into Expo.
Once I got home, I made a heavier-duty lead using 14-gauge wire and larger alligator clips so that I could finish out my week and come up with a better long-term solution.
That being said, I think I've figured it out.
Replacing that fuel pump relay is not an easy task as it requires completely uninstalling the entire fuse box, then carefully dismantling/opening the 'clam-shell' design, then de-soldering the OEM relay, soldering in the replacement relay then reassembly and finished off with re-installation into the truck.
I've decided to use a standard but HEAVY DUTY relay, powered off a switched lead to bypass the OEM relay but also, install a hidden toggle switch so I can essentially use this re-engineered design as an anti-theft device.
Thank you for reading this write-up and any comments/suggestions/advice is of course, welcomed.
CertusExpo
CertusExpo
Fort Worth, TX
doesn't the fuel pump relay just unplug from the CJB? I have never seen one that didn't
Apparently for this year Expo, there were two designs. One of which is the clamshell where some relays are INSIDE and UNDER the visible set of relays and fuses that are easily serviceable.
CertusExpo
CertusExpo
Fort Worth, TX
Added a picture showing how they are between and below the easily serviceable relays.
Here's a YouTube vid that shows the uninstalled board with the soldered on relays.
Bedrck47
Elizebethtown, PA
Had you simply read some of the threads about the relay You would have seen the post I have made about using a jumper
Once you prove with starter that the engine starts and now think its either the fuel pump or the relay then test for voltage at the shut off switch if you have voltage most likely bad fuel pump If no voltage then the relay is bad
Look at the video and about the 6 minute mark he starts to pointing to a dark green/yellow wire Look directly to the left of that wire in the other connector You see a RED wire put a jumper from the dark green/yellow wire to the red wire and you have bypassed the contacts on the fuel pump relay. A paper clip makes a good jumper
This procedure is safe and there will be no voltage to the pump when the key is off
CertusExpo
CertusExpo
Fort Worth, TX
I'm sorry I missed that! I was scanning through multiple threads on multiple forums as well as looking for 2nd Gen Expo specific videos. It all becomes white noise. I also didn't have a voltage tester with me so I was using the resources available to me.
Edit: Thank you for the info on the red wire. I will use that to run switched power off of. Do you happen to know where/what the red wire is feeding?
CertusExpo
CertusExpo
Fort Worth, TX
BEDRCK47,
Question:
I looked at that plug you mentioned and there is (From the top), Orange, Red, Red/Yellow. Which one of the two Reds are you referring to?
Bedrck47
Elizebethtown, PA
There is only ONE RED the other is red/yellow I will send you some more information a little later
Bedrck47
Elizebethtown, PA
Your welcome I wasn't trying to be a smart a$$ with the answer I understand you asking and making sure of the wire
Bedrck47
Elizebethtown, PA
See attached print
The connector with the dark green /yellow is C270K pin 3
The connector with the red wire is C270A pin 10
The jumper should only be used as a temporary means to bypass the contacts for the Fuel Pump Relay
Bedrck47
Elizebethtown, PA
You may have to print the diagram in the previous post to get a better view
Have attached some better prints
On 24-03 look for C270a red wire
On 24-09 look for C270k dk gn/ye wire
Those are where the jumper gets installed
  • 24-09.pdf
  • 24-03.pdf
CertusExpo
CertusExpo
Fort Worth, TX
So, after getting 100 miles to half a tank of gas, I realized the PCM is not just sending power to the relay but controlling the voltage therefore controlling the amount of fuel being supplied.
Now I'm wondering this. Could I just add a potentiometer like this one LINK to the circuit that would allow manual voltage control for low need scenarios such as surface street driving or stop and go traffic?
Bedrck47
Elizebethtown, PA
If you decide to replace the fuse box be careful Ford used two different fuse boxes in 2003 they are not interchangeable the replacement must have the same part number as the original
the complete part number is a combination of 12 numbers and letters
4 then 6 then 2 not just the 6 in the middle see the attached as an example
CertusExpo
CertusExpo
Fort Worth, TX
Thank you again because as a matter of fact, I'm getting ready to head out to Pick a Part.
By the way, what do you think of the potentiometer idea?
CertusExpo
CertusExpo
Fort Worth, TX
Have no idea if the PCM varies the voltage or not
I came across this thread LINK and please see the large paragraph under ***EXPLANATIONS***
"variable duty signal cycle to the fuel pump" which makes sense to me for fuel efficiency.
Edit: I'm also trying to avoid a situation like ExpyGirl03 had where she replaced the fuel pump relay only to have it burn up again by replacing it with an externally accessible and replaceable relay.
