Humming Noise
John Christopher
CT
I get a humming noise from the front end between 40 and 50 mph when on the gas. It sounds like its coming from the motor. If I go outside the 40 to 50 or let off the gas it stops. No one has been able to figure out what is causing the problem. The vehicle is an 03 Expy Eddie Bauer. Any ideas are welcomed. Thanks
Adieu
SoCal
Look at RPMs and coolant temps abd try to force it to do the same speed in another gear.... if it is SOLELY vehicle speed related, regardless of throttle position RPM gear and temperature then there are two distinct possibilities:
1) air leak in weatherstripping or sound caused by air rushing at/thru an aftermarket accessory or unique damage point specific to your vehicle (puncture in bumper, aftermarket mirror or luggage rack, bent body panels fitting irregularly etc. that create a specific noticeable note at a specific airspeed)
2) tire(s) out of balance / damaged rims making noise most noticeably at a specific speed
J
John Christopher
CT
Hi Adieu, I held the trans in 2nd gear and it still makes the noise after 40 mph. If I leave off the gas it stops. I guess that would rule out wind noise. Thanks for your reply.
Adieu
SoCal
...but it subsides after 50mph?
Hmm... do you have switchable AWD/4WD? If yes, what happens if you switch to 4A?
J
John Christopher
CT
AWD/4WD makes no difference. The noise is still there. It is harder to hear 45 and above because of the increased rpm in second gear.
ExpeditionAndy
Fort Wayne, Indiana
John does it change tone as you slow down or does it make an oscillating or warbling sound as you slow down? I had a bad rear bearing and a transfer case bearing that made that kind of a noise but I really heard them clearly when I was coasting to a stop and they changed their tone.
Another thing is what kind of shape are your tires in. Tires with a low amount of tread can make weird noises. When we bought my daughter her 2007 Fusion, I thought it had a rear wheel bearing going out. The dealer said it was the tires. We replaced the tires and the noise went completely away. So that is something to look at as well.
J
John Christopher
CT
The tone doesn't change, just goes away below 40 and hard to hear over 50. The tires are fine. It's the weirdest thing and no one has been able to figure it out. Thanks.
gulfman
Malvern, Pa
I have had a humming noise between 45mph and 60mph when on acceleration. Goes away on deceleration. At times it is hard to tell where it is coming from. This has been on going for a number of years. I found a TSB bulletin that fit the noise to some extent, in 2016. It was TSB 05-23-3. I took it to a Ford dealer in March of 2016 and the mechanic test drove it with me and said that he thought I was right. He said he had seen some other ford trucks with the same noise. He said that unless it got worse that he would let it go. I got a quote from the dealer to fix it per the TSB bulletin and that was $ 1,867. I have not fixed it yet. It is more noticeable in hot weather than cold weather. More noticeable the longer you drive in one trip. I don't know whether or not that is your problem. My Expedition is an Eddie Bauer 2003 with 52,000 miles.
J
John Christopher
CT
Hi Bob, I have the same problem between 40 and 50 mph. Do you know how to access the TSB? My truck is also an 03 Eddie Bauer but with 115,000 miles and its been making that noise for years. I wouldn't put that much money into fixing it. I'm use to it by now.
That looks like a nice boat your towing. What is it. I also tow a boat with mine. Thanks
Tdh777
Pensacola
I also have this problem 4.6 eb 03 expy. Have pinned it to the air box but can’t put my finger on exactly where the gap is. It is similar blowing over a coke bottle top. I am going to completely take out the air box and put something else there with a filter so it doesn’t have the factory box any more.
ExpeditionAndy
Fort Wayne, Indiana
It could be something simple like somebody removed the baffle that lowers the noise. I've read that the Cold Air Intakes increase the noise under the hood under certain conditions like heavy acceleration.
gulfman
Malvern, Pa
John,
Here is the TSB on the subject. I got the impression that this problem was not uncommon and continued for years in some of the Ford SUVs and trucks.
The boat is a 2010 Yamaha AR 240 Jet Boat.
  • TSB 05-23-3 Ford.pdf
J
John Christopher
CT
John,
Thanks for posting. I guess I just live with the noise. It isn't all that bad. My mechanic told me just speed up between 40 and 50. Funny!
