Odd noise
GngrBeardMan
GngrBeardMan
Navy
Boise, Id
I was able to get everything tight eventually. Alignment was way off but got an Alignment done at a local shop and she's running like a top now. Next project is a new radio. Trying to figure out what I need to make sure the steering wheel controls still work lol
whtbronco
Winchester, VA
I have this for my Kenwood head unit, Crux SWRFD-60L Wiring Interface. The steering wheel controls work okay. Sometimes the volume up button will change to the next song or radio station. Best thing I can recommend is to call Crutchfield. They will guide you right and they will be there years from now for troubleshooting assistance. I have called them many years after a purchase and they were more than happy to help me.
I'm sure Crutchfield is not perfect, but for more than 30yrs I have always been very pleased with the service they provide.
GngrBeardMan
GngrBeardMan
Navy
Boise, Id
I actually ended up going through Crutchfield for everything because of house awesome they are. I've had friends and family over the years that have had nothing but great experiences
GngrBeardMan
GngrBeardMan
Navy
Boise, Id
Everything was going great until I decided to test out my 4x4. She's really sluggish in 4x4 and it's noticeably louder. I got a check engine light so I switched it back to 2wd and pulled the codes. Got a P1867 in the "Enhanced Codes" section of my reader but it's not an active code. Gonna just stick with 2wd for now. Wondering what I might have done while switching the CV axle that might be causing this
whtbronco
Winchester, VA
How often do you use 4wd? If not often you may have a driveshaft u-joint that's stuck or rusted. If it was caused during the cv axle swap I would look at the IWE, integrated wheel end.
GngrBeardMan
GngrBeardMan
Navy
Boise, Id
I don't use it anywhere near as often as I wish I did LOL. In the winter I have it on auto four wheel drive just in case I need it but I don't have many opportunities if any take it off-road. I was looking for a place in my area where I could play around in the mud but haven't had any luck yet. Before I started having issues with the CV axle and control arm I had switched it into four wheel drive a couple different times just to make sure everything is working and didn't have any issues then.
AWAR
oregon
Everyone should also exercise four wheel low a couple times a year to make sure everything works as it should. I have a long gravel driveway so it is easy for me.
GngrBeardMan
GngrBeardMan
Navy
Boise, Id
I honestly don't think I've ever had it in 4 low. Maybe 8 times in 4 high over the past four years
whtbronco
Winchester, VA
I use 4Lo to get the truck on to ramps. All ya gotta do is hold the brakes and it will climb them at idle. So much less stressful than using throttle. This is just to shift into and out of 4Lo. 4Hi can be used from stop light to stop light in a straight line, no turns unless the road surface is slick or gravel. AWD use it every week or 2 even if just for 10-15 minutes or a couple miles. It'll spin everything and verify everything. If you hit the throttle in AWD coming out of a sharp turn it will increase the power sent to the front axle. Really pulls it through turns.
I used AWD 1 time in the snow/ice, never again. AWD is for dry or wet pavement only in my opinion. 4Hi is vastly superior to the unpredictable AWD when it's slick.
GngrBeardMan
GngrBeardMan
Navy
Boise, Id
So I haven't had an opportunity to do any more testing on the four-wheel drive or get it up on jack stands. about a month after my last post I noticed a hum coming from the front end that got louder and more high pitched the faster I go. At first I thought wheel bearing but the Moog wheel hubs i just installed came with new pre-greased wheel bearings so I'm not sure what else would make that same noise.
whtbronco
Winchester, VA
Wheel bearings and tires are the most likely culprits of a hum. I have confused tire noise for wheel bearing noise more times than I care to admit. Keep in mind failing wheel bearings will usually get louder or quieter in turns depending on the load.
If it's tires you can change the air pressure and/or rotate the tires to see if it changes pitch, volume or location.
Sometimes it's tough to identify the location though. Driving against something that will reflect the noise helps me, like a jersey wall, guard rail or even a just a simple curb if it's quiet outside and your windows are down.
Another thing is do not assume that your new part is good. I have made that simple mistake many times. You should be able to trust new parts, but sadly you simply cannot. I have recently pondered posting a thread on increasingly poor parts quality in fact.
Staff online
Al_Harley
