Snapped the 8mm rod that holds it, rounded the 18mm nut trying to impact it off
Filed/sawed off the top thinking I'd got at the threaded part so it would just drop through --- no dice I sawed thru a wider part.
Ideas, short of a new LCA? Can I drill the damn thing? Use some sort of grinding drill bit to destroy this "head" so it just falls out (don't see much chance for angle grinding since it's recessed)? Or??
Bottom end approach seems hopeless, the damn thing is in a stupid recessed nook deep in the LCA
