Rear Camera Settings
barrydu4
Louisiana
I just purchased a 2017 Ford Expedition Limited. I noticed that the back up camera shows only the lines to indicate how far I am from an object. I thought it would also show the curved lines indicating where I was backing up. It doesn't. Do I have it or not? My wife's old Explorer had it and it's an XLT.
Muddy Bean
I wondered the same thing when I bought ours. I’m used to it now...not sure why it’s a feature in some cameras and not others.
jkayca
Ottawa, On
I was disappointed not to see curved lines too. My guess is the software would need to know the steering wheel position to implement this and there is simply no input from it.
I have a 2015 Expediton Limited 4x4, purchased new.
Your vehicle owner’s manual should explain all the features of the backup camera system.
barrydu4
barrydu4
Louisiana
It works fine but I was just use the curved lines showing where you back up at an angle. Again my wife's old Explorer had them. No problem.
star-art
Pacific Northwest
It really sucks when Ford puts features like this on other vehicles and not our trucks. The F150 has it, the Explorer has it, and I'd bet other models do as well. There is a module called Steering Angle Sensor Module (SASM) on other models, that is likely recording the position of the wheel and putting that data on the CAN bus. Maybe the steering column in our trucks doesn't have this module so there is no steering angle input to the backup camera display.
chuck s
Been using mirrors all my life so a camera back there is handy but not paramount. Mirrors let me see the sides of the truck and help avoid mailbox posts that don't show up in the camera. I do find the rear camera extremely valuable for hooking up to trailers and it saves me several "get out and looks."
-- Chuck
barrydu4
barrydu4
Louisiana
That's true Chuck, but I still like the camera's ability to measure distance behind the Expedition. I always use the mirrors as the main tool when backing up.
07xln
Dallas
The sensors on the front suck!!! Yes they’re great when parking but other than that they’re horrible. I can be sitting in traffic or at a red light and can be 10ft from the car in front of me and it will start to randomly beep. If it’s raining and the car in front of me is kicking up a good spray it will cause it to randomly go off. Drives me crazy
East-TN
Air Force
TN
You might have a problem with your sensors...mine don’t do what you describe :33:
shanep99
This is my first post, I have a 2016 Ford Expedition Platinum 4X4, and I have found some good information on this site thanks to everyone for the collaborations. I have read on this forum and the Explorer and F-150 forums about others using an OBDII link and the FORScan software. FORScan is software used in conjunction with a specific type of OBDII adapter that enables you to make changes to your truck's default modules' settings.
I'm not sure, however, is this something that could help with the "Enhanced Park Aids" curved lines... Yet. If anyone has tried this and found out if it works that would be great! I would definitely like to implement that on my Expedition.
I like the idea of having the two side view mirrors reverse tilt when the vehicle is put in reverse and then you can set it so they auto fold when you lock your vehicle (Lincoln Style).
So many more options that can be set using the Forscan and OBDII Link. Heres a couple of links that I found really interesting about this:
Using the Forscan Software: https://docs.google.com/document/d/1-8dKaS_Spu4Zw4hV_CrKC4tLoP9G8yejqegF1wxIqxY/edit
List of Changes that can be made: https://docs.google.com/spreadsheet...iVSlDFGFHnfeuhb3RTMVz95730/edit#gid=815852466
From Ford Explorer Forum Options that can be changed:
https://www.icloud.com/numbers/0AtiYU-yJ4Nrfyfuzp-Mi0l8A#FORScan_2011-2018_Explorers
More possible changes:
https://docs.google.com/spreadsheets/d/1qf2gYgkhmsX-dnFO3Ki0nYUvr7aeLKsHsA0WxhDns1s/edit#gid=0
**REMEMBER To Always Make A Backup of your current working configuration before you make any changes.**
I hope this helps someone out. I am waiting to order my OBDII adapter and try a couple of small changes on my truck. I definitely want to get rid of the double horn honk when I leave the engine running and make a small pit stop. I will likely implement the reverse tilting mirrors as well.
Take care, wish you all the best on your 2017.
barrydu4
barrydu4
Louisiana
Chuck my wife likes the front beepers. She is bad a depth reception...lol. I like them too....lol On my old 2012 Expedition I did have some problems with the front sensors....but I learned to keep the clean and never had another problem again.
07xln
Dallas
Could be. It’s done it since new. It was actually raining the day I picked it up from the dealer and on the way home it beeped a few times. At this point it’s not worth a trip to the dealer as it’s random so with my luck they couldn’t get it to act up for them. Plus when it starts to do it I can just hit the ok button to turn it off
star-art
Pacific Northwest
Explorer owners report the "active guidelines" feature is available only on vehicles equipped with Active Park Assist. Expedition didn't get this until 2018. But, at least one person says they had them on an Explorer Limited that did not have this option.
2007-14 Expeditions do appear to have a steering angle sensor. I don't know for sure yet about 2015-17 but it's a good bet they do as well. F150s have them.
For 2015-17 Expedition with MyTouch or SYNC3, it *might* be possible to enable "active guidelines" using FORScan. Hopefully someone on this forum can figure it out. Here's more info:
http://www.forscan.org/forum/viewtopic.php?f=6&t=2087
