Adieu
SoCal
Ordered front/rear pads (Akebono ASP) and front rotors (Raybestos Police). $252 OTD. Only the fronts need to be done, but Pep Boys has the pads at 25% off so I'll toss them in the garage until they're needed.
Just out of curiosity, do those PIAAs actually put out sufficient light to warrant their cost these days? I had a set way back in the late 90s and they were awesome, but reviews on the modern iterations are pretty lackluster. The stocks are ok, but I do a lot of driving on NPS roads and could really use something better.
Which generation are you trying to fit? Since you're asking about round lights....if stock 3rd gen, Morimoto & JW Speaker make some nice projector LED units....and the Chinese make a VERY decenr inspired-by sorta-knockoff.
They're all labelled as F150 products but will fit, either bolt right up or very minor trimming to housing
And if you want round lights mounted elsewhere, on a bull bar, custom bumper, whatever, there's tons of different 4" round projector LED units marketed for Jeep and Harley applications
Adieu
SoCal
My neighbor had a screw in a tire making it flat overnight. They ended up having to replace all 4. Shop said where the screw was they couldn't reliably fix with a plug & the tires were worn enough that putting a new one on would create a problem.
The days when I actually want to change a tire or fix a flat with a plug are behind me. Kinda like my roof. I put a complete roof on my house in 1989. Now days, I do not believe I can hoist a pack of shingles up a ladder over and over again. Glad to pay somebody to do that.
All new-tire shops ALWAYS say that.
Especially to people who don't ask for their tires back... they just sold ~$1k of tires, $100+ install labor, and acquired 4 free tires to sell at their used-tire-shop affiliate
ManUpOrShutUp
3rd gen in the stock location. I did consider the Morimotos or some other type of LED, but I've been less-than-impressed with my Rigid LED backup lights and the reviews for the Morimoto LEDs are mixed.
Adieu
SoCal
Get Liteway for F150 , similar to Morimoto/JW Speaker.
Near-plug and play install. Requires minor trimming of a couple tabs on your housings with a sharp knife, takes like 5 minutes tops.
They're far superior to stock and a lot better than even quite-nice LED bulbs in reflectors....better than cheap HID, too.
and they only cost $52 ish
Boose
2017 Platinum EL
NJ
Did she hit another vehicle or something else?
She rear ended a Dodge Ram pick up. Accelerating at a merge without looking... she hit the gas before she looked ahead.
Boose
2017 Platinum EL
NJ
Is she ok?
Looks like a pretty solid front end hit
No injuries thank God... just a lot of broken plastic and mangled aluminum. The Rams tailgate was a little wrinkled. It looks a lot worse then it was. She didn' have all that much space to get up much speed.
Dorzak
Good to hear there was no injuries.
ManUpOrShutUp
I started noticing some scraping/grinding coming from one of the front wheels about a week ago. I need front rotors/pads so at first that's what I thought it was. As the noise got louder and louder over the last few days, I noticed it was continuing even after I let off the brake. I suspected a wheel bearing so tonight I put in N, jacked the front end up, and gave the wheels a spin. Sure enough, the front left wheel barely turns at all by hand. On the bright side, replacing the bearing/hub assembly isn't much work on top of the brake job. :D
ManUpOrShutUp
Front pads/rotors done and driver side wheel bearing & hub assembly done today. On a side note, after buying one assembly and then returning because I found a better price, I learned that some MOOG-branded #515142 assemblies are made by MOOG and others are made by SKF.
