Mirrors/seats moving erratically when unlocking with key fob
makenzie71
Tx
2005 Eddie Bauer trim
About 3/4 of the time we unlock the truck with the key fob the seats and mirrors move all over the place and never go to the memory setting. The mirrors actually move to their limit and then start skipping teeth trying to keep going. Sometimes when we unlock with the same fob we used to lock up everything is fine. Every time we unlock with the other fob the seat and mirrors go nuts. Usually when pushing the memory buttons on the door it works okay, about sometimes the setup goes nuts even then.
Anyone seen this kind of problem?
Also, I’m curious how big a deal it would be to add power folding mirrors. I know it was an option on the 05+ models...would that mean that the wiring is already there and I just need to located the switch and mirrors? Any insight here would be appreciated.
Prince_Polaris
I have a similar problem, but not with the keyfob, it's with the Auto-Tilt-Down when I shift in or out of reverse. Sometimes when I've shifted in or out of R, it does that same thing you mentioned, it moves all the way to a certain direction, skips teeth, then gives up.
M
makenzie71
Tx
Can anyone identify what module stores the memory for the seats/mirrors? I'm thinking I'd like to just replace it and see if the situation gets better.
Bob Lewis
Pisek, North Dakota
We had the same problem with our 2003. I had replaced the Ignition switch after watching a YouTube video that showed a sensor connection act up when the key was in the ignition. No luck with that. I had planned to try to fix it, but ended up being out of commission due to a broken shoulder. Finally took it to the dealer and it turned out to be "a connector under the driver seat". I had tried to locate any wires with a splice on the driver and passenger side kick panels with no luck, but I was told that is a failure mode on these, too.
Good luck with yours.
gulfman
Malvern, Pa
I had the unauthorized movement happen often with my passenger side mirror. One day I hit the garage door and broke the whole mirror. I replaced the entire mirror and have not had the issue again in over a year. I figured it must have been the motor mechanism in the mirror that was going crazy. 2003 Expedition
delawhere23
Delaware
The Seat Memory Module is bad. You can replace it yourself, but it will need programming. Had mine done 4 years ago, no problems since. Also, replaced the mirror motors because they did not move smoothly.
Tdh777
Pensacola
Is there a way to just turn the seat memory off ? I don't use it anyway. Just want the mirror gremlins to go away
Hamfisted
Ft Lauderdale
You just need to program your key FOB to your seat memory module. Simple.
Programming Ford Key and FOB
Step-by-Step Ford Key Fob Programming Instructions
  1. Close the car doors, then open the driver-side door. Press the UNLOCK button on the driver-side door.
  2. Next, turn the ignition from OFF to RUN 8 times. Do this within 10 seconds, making sure the 8th time ends on RUN. When you’ve entered programming mode, the door locks will lock and unlock. (Note: If the doors don’t cycle, turn the key faster. Your car may not have keyless entry if you still can’t get the doors locks to cycle.)
  3. Press any button on the Ford remote to be programmed. Do this within 8 seconds. The door locks will cycle again to confirm the keyless entry remote is programmed and ready to use.
  4. Have a second remote key fob? Again, press any button on the remote within 8 seconds to cycle the door locks. Repeat this step for any additional key fobs.
  5. Finally, turn the ignition to OFF. The locks will again cycle to confirm programming is complete.
Transponder Key Programming
You must have 2 original keys that start your engine to perform this procedure. If you only have one working key or none at all it must be programmed by a dealer or locksmith! ( ForScan also works for this....) Your New third (unprogrammed) key must also be cut prior to performing this procedure.
Please Note: If one of your keys is a cloned key from a hardware store this procedure will NOT work. This procedure requires original programmed keys.
1. Insert an existing (working) key into the ignition cylinder.
2. Turn the ignition cylinder ON (just shy of starting the car Without cranking the engine) and back to OFF. Ignition should stay in ON position for at least one second.
3. Remove the existing key and WITHIN TEN SECONDS, insert a second working key and turn to ON and then back to OFF. Ignition must be on for at least one second but no more than ten seconds. Remove key.
4. Insert the New (unprogrammed) key before twenty seconds have elapsed and turn to ON. Leave it in the ON position for at least one second and turn back to OFF.
5. The security light will light up for THREE seconds to indicate the new key has been successfully programmed.
Setting Up Your Ford Memory Seats
Once you’ve got your seat, mirrors, telescopic steering column, and power pedals in the proper place, turn the key to put the ignition in the “On” position. Once you’ve got the power on, you’ll notice three buttons on the side panel of the driver’s side door. Press and hold the number 1 button for about five seconds until you hear a single chime. After the chime sounds, let go of the button and your seat settings have been saved! To test it out, simply move something a hair and press the button to watch it go back to your set position.
Setting Up Ford Key Fob Memory
For those times when you want your seat to be ready for you before you get inside your Ford vehicle, the key fob that you received with your vehicle can activate the memory seats for you! To sync your key fob with your memory seats, do everything we talked about earlier, except this time keep holding the appropriate memory button until you hear the chime twice. As soon as you hear the second chime, press the lock button on your key fob immediately. Now, every time you press the unlock button, your seat will automatically adjust to your preferred settings. This is especially helpful if you make use out of the easy entry and easy exit feature which moves the steering wheel and seat each time you get in and get out of your Ford.
