Mike Wolfe
Anyone using E85 in their vehicle of any make or model?
If so what has your experience been while using this fuel
Newer vehicles have the same fuel system (2016 thru 2019 production) so I have been toldMy 07’ Expy is the regular 5.4L V8, didn’t get the flex fuel variant. Ford says the flex fuel variant receives a different fuel system (lines, injectors, pump) than the E-10 variant. The 5.4L loves E-85, runs smooth and power is increased across the entire band.
I was pleasantly surprised to find a detailed explanation of ethanol content present at the E85 pump, at this station.
BTW, I didn't realize the fillerneck on my '18 actually says E0-E15. Thought it showed E10 as the limit.
This station also sells E15 in addition to the E85. So I decided to try a few gallons. Unfortunately the E15 here is rated at 88 octane. The E85 only shows an octane rating of 94, which I found a bit odd, but better to be odd, than misleading, I suppose.
Should have checked the picture before leaving. On the upper portion of the yellow panel reads a statement "contains between 51%-85% ethanol." That is the part I was surprised to see. Hopefully it is required to be posted rather than a commercial enterprise deciding on it's own to further educate the consumer.
Wow fuel is sure a lot cheaper there than it is in arizona
Here E85 sells for $2.499 & premium is around $3.499 to 3.799
Surprised to see FLEX FUEL is only 94 octane & e15 is only 88
They must use some really low octane gasoline when blending it
Could simply be a C.Y.A. deal, under promises/over delivers.
We're relatively close to refineries. This particular station is 300 yards from the other station that sells E0 93 octane. Not in "city" or off a freeway interchange, but not so far into bfe that the price starts to creep back up to levels of off freeway stations, either. It's also a chain enterprise, I think from PA, surely that also helps keeps prices low. Supposed to be top tier fuel.
Oh god, here we go again!E85 is another ethanol scam. Less MPG and little or no savings. In theory an engine could run higher compression(14-18psi), with no spark detonation. It would be an E85 only, however. Auto manufactures have not made such an engine. On a regular 9-1 its makes no difference. Ethanol absorbs water and causes condensation in the engine. An E85 vehicle must have stainless lines and upgraded seals and gaskets. The 'corn lobby' pushed for this nonsense. It cost more to produce ethanol and uses more energy, than it saves. It raises food prices.
Smart ass, state you point or don't post. What do you disagree with? Ethanol is corporate welfare, for the corn industry. It lowers MPG(3-30%), Raises gas prices, raise food prices, ruins small engines, it takes energy to distill ethanol from corm(more CO2). It cost more, you get less and tree hugging Americans, feel good about it? A high compression engine would benefit from Ethanol's 100+ octane, but no manufacture offers one.edizzle
Some folks are just uniformed & misinformed with false data
No point in trying to explain facts to them
So will not start another battle![]()
@5600 rpm? Come on, really? Even @ 4100rpm the motor is outside its comfort zone. 1200-2200 is the normal power band. What is the specs in that range. My last point, is ethanol is so great, why did the government 'mandate it' (force it to be blended, at additional expense)? Why is there not more cars E85 capable? Ethanol free gas is available, but its sold higher than premium? Why use corn, when there is an alternative, that works better? The higher octane, would only benefit a high compression engine(not a stock one, that runs on 87). The coup de gras, Ethanol 'phase separation'(30 day shelf life). Corn used to feed cattle and used in food is more expensive, because its being used to make fuel.FYI everyone
Most engines produce more power on ethanol blends
Here is a comparison of the GM 5.3L N/A engine
Horsepower (hp / kW @ rpm):
355 / 250 @ 5600 (gas – SAE certified)
380 / 283 @ 5600 (E85 – SAE certified)
Torque (lb-ft / Nm @ rpm):
383 / 519 @ 4100 (gas – SAE certified)
416 / 564 @ 4100 (E85 – SAE certified)
About a 10-15% increase with E85
Read more: http://gmauthority.com/blog/gm/gm-engines/l83/#ixzz5Y4LOLlh3
