Physically damaged Cam Pos Sensor
silentdub
Philadelphia
Hey guys, We have a 2005 Ford Expedition, 5.4L and there was a code for the CAM POS Sesnor, bank 2. When I removed the old sensor it was clearly damaged, the plastic was broken and worn away. We replaced the cam sensor and within a few days, the same code came back, we pulled the sensor and again, the brand new sensor is damaged the same way.
The only two things I can see it hitting is the timing plate or the chain itself. There are no other noises or concerns at this point, just broken sensors.
Is this a sign that the chains/tensioner/guidessensor.jpg need to be replaced?
Hamfisted
Ft Lauderdale
Are you getting any "rattling" from the timing chains on cold starts ? Do you have a bore scope tool you can look in the hole and see what it's hitting ? Should be marks on the chain if that's the cause. How many miles on the Expy? Have the chain sets ever been changed before ?
Trainmaster
Old School Member
Rockaway Beach, NY
I know some aftermarket sensors for BMW's are too long and break off just like that. Maybe wishful thinking that you have cheap knock-off sensors. I'd get one more Motorcraft sensor just to be sure, or at least compare yours with a real one to make sure the sensor depth isn't your problem.
If that's not it, you're going in... And it's getting cold in Phily.
S
silentdub
Philadelphia
I didn't hear noise or rattles. We have a scope and plan to do that next. I doubt the chains were ever done, i know they're common for failure. There's nothing else that it can hit, I though the cam sensor picks up off the cam gear which makes the chain that much further away. Strange.
S
silentdub
Philadelphia
The one we replaced was damaged too, had some cracks in the plastic. I have a feeling it was replaced previously but no telling. I'll check the length though, still going to spin the motor and scope it. We have a good scope and nice screen so we should be able to see something.
