Looks like no Expeditions are recalled. Which translates to “There aren’t as many units so we will just ignore that model”.
More specifically, there have not been sufficient enough complaints to the government to trigger the recall ! I guarantee, it is the exact same transmission, built in the same transmission plant
(pretty sure they come out of Livonia) with the exact same software.
Now those of you who have knowledge of these thing might wonder, "How in the H-E-double-hocket sticks can software fix a bad sensor ?" Having "been there", the fix is likely going to be something like this. We all know it is impossible for transmission to have a zero output shaft speed if the rear wheel are turning. The ABS knows the rear wheels are turning so they send that "speed" to the powertrain computer
(likely a fraction of a second delay). The logic in the transmission software says something like "Oh, look, the output shaft speed just went from X to zero, but we are going to wait until we get confirmation from the ABS before doing anything !"
(Yes, it is possible to go from X to zero instantaneously when you lock the brakes up.)
Furthermore, the software goes into a kind of a limp home mode, delaying any shift until the vehicle speed is confirmed by the ABS and lights the light on the dash board. So the fix of changing the software was cheap and the customer still gets stuck with the bill to change the lead frame and output shaft speed sensor !
