Dorzak
Went to see about changing the rear wiper and found it was broken and had been glued in a couple places. Ordered a replacement, and we will see.
This is the arm you seek so you can just buy any old 17” blade (I think that is the right length) off the shelf and not have to use the crappy overpriced proprietary Ford blade.
Dorman 42651 Wiper Arm https://www.amazon.com/dp/B0010DPB00/ref=cm_sw_r_cp_api_i_1s1ACbKMSMZBW
Amazon "thinks" https://www.amazon.com/Ford-9L1Z-17...------------&vehicleName=2016+Ford+Expedition is the right arm for the 2016. (And it is) The Dorman arm fits the hub on the motor and will replace the original Ford arm which is kinda fragile to me. Don't lift the original too high off the glass, it'll snap the "tail" off. (Ask me how I know).This link says "This does not fit your: 2016 Ford Expedition" ?
Thx, just wanted to dbl check.Go read the link I posted. It definitely fits. You can see it installed on my 17, with a 17 Inch Icon Blade. Amazon does not know all.
great reading on wiper. How do set the fricken wiper so its sits perfectly level all the time. Whenever hatch opens wiper hangs down again. Is there a stop we can adjust how low it goes ? Looks sloppy when its not level. Bought vehicle like this
Unscrew the nut and rotate the arm slightly whichever way will make it level and retighten the nut.
With the After market Arm you need to pry it up after you loosen, because it installs solid!
Amazon says this will not fit my 2010. Are you pretty sure it does?
