Rear wiper broke
Dorzak
Went to see about changing the rear wiper and found it was broken and had been glued in a couple places. Ordered a replacement, and we will see.
Moderator
There are several aftermarket solutions that are MUCH better than stock. Cancel your order, and do a search on here for the thread.
The aftermarket arm allows you to use a common aftermarket blade. It is great!!! I have a Bosch Icon on mine, and it is night and day better. Plus knowing I grab any wiper the right length from the Auto Parts store is a big plus!
Moderator
mquick5
Buckeye Country
iimagine
2016 EL XLT
mquick5
Buckeye Country
Moderator
This link says "This does not fit your: 2016 Ford Expedition" ?
Go read the link I posted. It definitely fits. You can see it installed on my 17, with a 17 Inch Icon Blade. Amazon does not know all.
mquick5
Buckeye Country
Thx, just wanted to dbl check.
getrdone
ontario
great reading on wiper. How do set the fricken wiper so its sits perfectly level all the time. Whenever hatch opens wiper hangs down again. Is there a stop we can adjust how low it goes ? Looks sloppy when its not level. Bought vehicle like this
Black
Kentucky
Unscrew the nut and rotate the arm slightly whichever way will make it level and retighten the nut.
Moderator
With the After market Arm you need to pry it up after you loosen, because it installs solid!
Black
Kentucky
I have had the Dorman arm in my Amazon wishlist for months now just never bothered to order it since my wiper was still good.
We’ve needed an Ark here in central Ky over the past month or so and mine was finally shot.
So reading this thread I ordered the arm on Monday they even had a warehouse deal for 9.75 on the arm and picked up a 17” conventional blade for $7 today. Both parts still cheaper than the stupid blade from Ford alone.
So it actually quit raining tonight so I popped the new one on.
Damn skippy you weren’t kidding the factory arm was on there tight. Had to get behind it with metal scraper and wiggle it off. When it finally broke lose sounded like a gunshot.
Dennis_H
DFW, TX
I replaced with the Dorman arm yesterday. Sprayed the stud with WD40 and let it sit for a bit. Used a pushclip remover and wiggled it till it finally broke loose. My wiper still worked, but the stupid little plastic cap over the nut was gone and that bugged me. I tried to order 2 different covers and couldn't get the right one sent, so I bought a new arm. Used the 17 " blade and it works perfect. Thanks for the info in this thread.
Andy B
Redding, CT
Black
Kentucky
Amazon says this will not fit my 2010. Are you pretty sure it does?
I have a 16 and Amazon says it does not fit though it does just fine.
Pretty sure the 10s have the same input shaft.
As long as you have the input shaft with a nut it should fit just fine.
No members online now.
rockinghranch
