Thts bizarre, my fronts were f’ed up at 17,000 miles and when they removed them from the caliper, one split in half and the other had full width fractures in the pad. Then they found out I had two bad 4x4 actuator assemblies. Fixed everything and they tried to get me paying for pads and resurfacing rotors. Long story short, they determined faulty pads led to warped front rotors so I got all new stuff for free. I never had rear brake issues though..
Both sides of ONE rotor (outside & inside pad) or Both rotors (outside pads)?Pad wear on the rear. Both sides look just alike.
Ok, maybe warped isn’t the correct terminology. There were several relatively deep scours in the rotor faces from dirt and debris stuck between them and the pads.Both sides of ONE rotor (outside & inside pad) or Both rotors (outside pads)?
If one end of pad backing wasn't sliding due to metal tang interference or other reason?
Should be able to tell when disassembling.
On the warped rotors ... there is a school of thought that rotors don't warp.
I guess you're not in that school. I've never had a warped rotor so I dunno.
I would clean/lube the slides and pins.
"MrSticker, post: 342565, member: 52783"]Watched that video, stopped it ... Still hard to see what's going on with those pads on my smartphone. Don't get mad at me for saying this but I don't buy that is normal wear. Even if a pad looks tapered in a video ... The guy doesn't point at it and say its normal. How could a tapered pad be normal? I've never seen one. Has any of the other Forum members seen it routinely?
