Intelligent key, proximity unlocking
creef14
VA
On my wife’s 17 Escape you walk up with the key in your pocket, grab the door handle and it unlocks.
On my 17 Expy I have to hit a button on the door keypad for the door to unlock. I don’t have to take the key out but I do have to press the button.
Is there a way to make it so I can just grab and go? ForScan maybe?
16plati
VA
No, her escape has a lock/unlock sensor built into the door handle sonas long as the key is close enough, whether out or in a pocket, it will open. I just push a button on the key pad to get in if I don’t feel like taking keys out
C
creef14
VA
Thanks. That’s what I thought.
Figured I’d ask on the off chance I was missing something
mossback
2017 Limited EL
WA state
I wouldn't rule out the possibility entirely. The truck has the sensor and knows/acknowledges when the FOB is in close proximity. Hence the ability to just press a key to open the door. The hardware seems to all be in place (sensor and remote unlock). It could be something that, with the correct parameter adjusted, can be enabled with ForScan. While searching for secure idle I did quite a bit of trial and error in there. Many possibilities but it can be tricky/risky to just poke around. Makes one appreciate the time and effort that went into the various settings spreadsheets out there.
Staff online
castawaypaul
