So from the sounds of your situation, this idea probably won't work but you could try running E85. The catch is, you need a tune and/or tuner to make it work properly which both cost a decent amount.
Whether this is a viable option or not, here is a little info. I run E85 regularly and lose about 2 MPG (15 - 13). That's something like a 13% loss I think. I break even here in Texas but I don't run it to save money. In Cali where the price of E85 seems to vary from 20 - 30% less, you might save money over the long run. From what I have seen online, it will cause extra wear and tear on the fuel system but can be done without many problems. Long term, I have no idea what it might effect. Also, it doesn't like the cold. Starts get harder 60F and below I've noticed, unless you bump up the initial start fuel and even then, it only helps a to a degree.
I have done most basic mods that people talk about to save MPG (exhaust, headers, intake, tunes, underdrive pulleys, electric fans) and what I've found is that they don't quite have the effect most people hope for. In all honesty, you will not recoup your investment. In my opinion, assuming keeping the truck is your only option, your best bet is to reduce weight and change your driving habits.
If you can, swap it for a beater that gets better gas mileage.
I hope you're able to get that job. Make a good resume and send it out to as many people as you can. Most schools have some kind of a job portal to help students get both on and off campus jobs as well. Apply for scholarships. For a quick buck, donate plasma. That could make enough to be gas money. I apologize if I'm just repeating stuff you already know.
Also, I'm not very active in this forum so I'm not sure if it's my place to say this, and this is just my perception, but it's unfortunate how many times I see threads being turned political like this one. I can see why people might be defensive, some of these comments come off as attacks. Every one is entitled to their opinion, but that's what the lounge is for. Post your ideas and help each other out or GTFOMF. Just my 0.2
