Rumbling noise on turning 2017 exp LTD EL
rich6655
Milan, Michigan
I had the same symptoms at 71k. Shuddering while at low speeds turning both left and right. I went ahead and changed out the oil on the rear axle and used full synthetic and added a Ford XL-3 friction enhancer and after 100 miles the shuddering went away. Saved a trip to the dealer and a $190 service fee just to look at the truck.
Black
Kentucky
It sounds like its your rear end. The limited slip clutch packs are binding a little. Mine does it every morning. When I leave out of my driveway it feels like the rear axle is locked. I have read that you can ad a "friction modifier" to the rear gear lube and it will solve the problem.
I would swap all the fluid if you think that is the issue not just add friction modifier.
Captain Kirk
Pittsburgh
I had my front, center and rear diff fluid changed. The sound still happened. The F-150 forums talk about the sound and most people said the "friction modifier" was the solution.
I'm not going to worry about it because my sound goes away after a few minutes of driving.
AccraBob
New Jersey
My 2017 expedition makes a rumbling noise on turning, either right or left. Had tires rotated and alignment done. Still rumbles. Any advice?
I don't know if this is related to the issue you're experiencing, but I have noticed that consistently in 3rd Gen Expeditions (I drive a 2009 and 2014 generally) when you turn extreme right or left, at the steering wheel limits, it will "chatter" - you could call it rumble. I first noticed this when doing a tight U-turn. If I switch the truck from 4A to 2H, the problem does not occur. I suspect that on dry pavement when the system sees a significant rotation speed difference between the two front tires (tire on the outside of the turn will rotate faster than the other), the 4WD kicks in when in automatic mode. Force it to be in 2H and it doesn't happen. Give that a try and see if it makes any difference.
16plati
VA
I don't know if this is related to the issue you're experiencing, but I have noticed that consistently in 3rd Gen Expeditions (I drive a 2009 and 2014 generally) when you turn extreme right or left, at the steering wheel limits, it will "chatter" - you could call it rumble. I firtst noticed this when doing a tight U-turn. If I switch the truck from 4A to 2H, the problem does not occur. I suspect that on dry pavement when the system sees a significant rotation speed difference between the two front tires (tire on the outside of the turn will rotate faster than the other), the 4WD kicks in when in automatic mode. Force it to be in 2H and it doesn't happen. Give that a try and see if it makes any difference.
You should not be making any type of tight turns in 4WD anything. Great way to really bind everything up..
16plati
VA
Why would it be the rear if I only feel it up front and it’s a rotational sound that follows the rotation of the tires?
16plati
VA
DO NOT USE FRICTION MODIFIER UNLESS DOIN A FULL DIFFERENTIAL SERVICE!
My 2016 has 39,000 miles on it, has never been off-road, and has never towed. If my clutch packs are shot already I’m going to buy a Chevy
jeff kushner
North of Annapolis
The OP might want to look up the TSB's for his truck....vac line has a spot where the clamp holding it can be damaged...the other thing is to replace the vacuum check valve and /or solenoid....
16plati
VA
Yup check valve and solenoid about $35. Easy 5 minute fix
Sgt Darkness
East Tennessee
Also, if the tie rod ball joint is bad or going bad normally you would feel vibration through the steering wheel at normal highway speed. Grab the tie rods and if they are not tight then I would replace them. Tie rod separation at speed would not be a pleasant thing to have happen. Please let us know on the outcome.......
16plati
VA
Tie rods are all tight. Only rumbling and vibration I get is after starting the truck up and pulling out of a parking spot. Only feel it in pedal and steering column
Sgt Darkness
East Tennessee
You might want a Dodge then because if I’m not mistaken Chevy is using same trans as ours in several of their newer models.
AccraBob
New Jersey
I think the assumption I had and that most people have is that in 4A, it stays in 2H unless road conditions tell it to kick into 4H. The tight turn on dry road apparently kicks it into 4H during that turn.
Moderator
Running around in 4A will hurt your MPG. No need for it unless the weather is bad.
Eagle 71
Nebraska
Cynthia, I'm assuming you're Expy is still under the OEM warranty. If so, what has your local Ford dealership told you what the problem was?
I'm assuming it's the CV axle, but you initially stated the rumbling happened when you made a right OR left turn. Does it still rumble on both sides when you make a turn? If it's localized to one side (a left turn, for example), then the culprit would be the right CV axle. Something to mention to your mechanic...
Sgt Darkness
East Tennessee
Dodge 3500 longbed dually it will be then
I’ll take one too....but the grand rug rats wouldn't like it a bit.....they gotta b able to fight between 2nd and third row seats. U raise your own kids then u get the benefit of raising their kids....cool deal....
16plati
VA
Hahahahahah I hear ya!
Matticus
Salt Lake City
You could also check to see if your brakes are hanging up. It's possible something is happening after the car sits for a while that causes the brakes to not retract all the way. I've always noticed that, when turning, any clearance issue with brakes is exacerbated. It's usually more of a scraping/rubbing sound, but it could be translating into a vibration/rumbling noise
16plati
VA
Great point! I’m gonna be getting powerstops soon
