How’s your tire pressure?It doesn’t matter if it is in 4WD or not. Still rumbles when turning.
I’ve tested this on mine as well. Truck up on jacks, turn on, 2WD, tires both spin and CV axles stay put. Turn to 4WD, spin tire and CV axle spins with it. Normal operation, correct?My next thought is that the front is staying engaged in 4WD even though the center is not. Thinks it’s not in 4, but front still is. Simple way to tell would be to lift the front up, spin a wheel and see if the opposite or front drive shaft spin.
Yup engage 4WD and they lock to the wheelsNo. If both wheels spin when you spin one, the hubs are not unlocking. That is your issue.
Nevermind, you said CV stays put. If both wheels in 2WD spin independent of each other your Hubs are working.
Funny you say that bc I did just that yesterday with a buddy. Found a parking lot, 2WD, full turn left and full turn right, both times the CV axles stayed disengaged from the wheels and operated normally.This is a bit of a stretch, maybe not even viable? You say its not in 4WD meaning the switch isn't in that position and the status lights don't say its in 4WD … but maybe something malfunctioned and it really is? If it always "rumbles" while turning either direction, is it the outboard front tire scrubbing because its stuck in 4WD? Any way to test that? A slow sharp turn on pavement? Maybe then put it in 4WD and see if its does the exact same thing?
OK .. its a l o n g shot
Have you greased the little bump stops on the lower control arms? They are actual bumps that when you go full lock they will tend to rub on the little pockets they fit in toAlignment was done yesterday. Didn’t help.
Update on my rumbling..No. If both wheels spin when you spin one, the hubs are not unlocking. That is your issue.
