Grille parts/trim
HawkX66
Semper Fi!
VA/MA
I found a new factory grille finally for my 17 Expy without having to be ***** for $600+. It was bad enough at $200, but a little easier to stomach. The only issue is that it's missing the insert trim pieces. Those must be the parts that are different between the different grilles right? I know King Ranch, Platinum etc all have different part numbers. Chrome vs Satin Aluminum for the Platinum etc.
My question is, are these parts available separately? I didn't see them on a couple of sites I looked at.
Thanks.
HawkX66
HawkX66
Semper Fi!
VA/MA
I don't think they're available separately, so by chance I checked eBay. Found a brand new set for $50 and the lister also said they aren't available separately. Sold... So now I'm at $250 all in for a new grille. I'm still not complaining.
Black
Kentucky
Can you pull the ones from the old Grille?
Where did you get the $200 part
HawkX66
HawkX66
Semper Fi!
VA/MA
There weren't any pieces left of the old grille. They were all tossed probably. It took the hit dead center so I doubt they would have been salvageable. I've been looking since I bought my Ex last year. I finally found this one at a boneyard in Texas. Not a scratch on it.
Insurance not involved?
HawkX66
HawkX66
Semper Fi!
VA/MA
I received my grille and inserts. When I went to install the inserts I found there were tabs on them that correspond to blank uncut slots that look like they're supposed to be cut out. The tabs also look like they're designed to break off easily. I'm wondering if I should cut the slots in my new grill or break off the tabs...
HawkX66
HawkX66
Semper Fi!
VA/MA
In case anyone else comes across this... The tabs get snapped off by the looks of it. Here is a shot of the back side of the trim removed from a stock grille and a pic of a new grille not installed yet. You can see the used grille has the tabs snapped off and the new grille still has them on. I don't think the used one has them snapped off as a result of being damaged.
MMMM
I know this is an old post, but has anybody come across any of these? I'm missing a lower insert.
Thunderbirdsport
Missouri
You might try a junkyard, some of the bigger chains have online inventories you can search, probably be easier, much less cheaper to go that route rather than buy the whole set online. I'm just making an assumption, though. Mine's an '11 and I stuck a Stehl grille on it lol
MMMM
Yeah, not sure why these have so many parts that you can't get separately. The newer models have show individual parts.
Junkyards are still asking hefty prices for these and new is just crazy. It seems that I just need to get lucky on eBay
