jeff kushner
ERZ.....listen to loki....he knows this stuff. You and I are nearly the same age....old.....but I can tell you that I would not have bought bought a new 17 if the previous two were not good, solid & reliable.
I bought my '17 new in Nov '16....I have 68K on it. Original tires/brakes/rotors/......nothing has broken, it has never been to any repair facility other than to repair recurring crash damage(I hit crap). The front pads will be replaced one of these w/e's. The new ones are on the end table but 70K for front pads is pretty impressive for a 6K pound truck.
Idle is a little rough some days, prob due to debris on one of the sensors. A nice washing down of the throttle body ought to clear it up.
Overall, coming up on 3 yrs and not a single issue other than it used to grind a tiny bit when pulling forward while cold....replacing the rear end fluid(I used Marine grade non-syn + the Friction modifier) ended that.
You've been a member since you've owned your truck, you've read the posts....you know these (15-17) are solid trucks.....you're just pissed at the dealer for jerking your chain. Hell brother, you prob know more about your truck than most of the "parts changers" at the dealer.
Good luck,
jeff
Good luck,
jeff
