I'm going to have to search for the paperwork. But I will get back to you in a couple days. It will take me a while to find itWould you have the part number from your repair invoice? Thank you.
Sent from my Moto Z (2) using Tapatalk
I have a 2015 limited demo with 5000 miles bought in 2016. Went up to 20k miles before problems started to show up. First was the front rotors getting warped. Brought to the dealership to get them turned, the service adviser told me the front pads where worn out. I told him to just resurface rotors and I'll fix the pads myself. When the truck was returned, they charge me almost $600 for pads and rotors. I complained to the manager and they gave me the rotors and pads free of charge. After that, I was driving the truck for a few days when I noticed that the front driver side wheel was scorching hot. I checked the pads, one was worn out at an angle and that side of the rotor had a mirror finish. Turns out the dealer installed all the inner pads on the driver side and outer pads on the passenger side. so I changed all four rotors and pads myself. At that time, I noticed that both front struts where leaking fluid, so I went back to the dealer to have it repaired under warranty. I left the truck at the dealer for the day and did not hear a word from them until I called them to find out what they plan to do. Dealer told me that the fluid leak was normal and no repair was needed. So I took the truck home and bought parts online and replaced them myself. Now at 45k, the AC blower stops working when you crank it up in hot weather and the front driver side tie rod boot is torn and leaking out grease. I already bought parts to replace them. I just need to find time and nice weather to fix them. I would never again take my truck to a Texas ford dealer except for maybe oil changes.
Still good to go?
Add the transmission cooler, it is pretty easy to do. Towing 6k pounds in the mountains, my 17 EL never goes higher than 212 and only peaks there for a few seconds.
Yep. Bought our 2016 used in 2017 and now have 92,*** miles on it. Stock except for a 5 star 87 perf/tow tune and changing it to side exit exhaust. Synthetic oil changes every 5k since new, air filters every 10k, I've serviced the T case, trans, and both differentials once, and changed the spark plugs and boots. Original brakes still. The only problem I've had was the blow off valve diaphragm, which tore, that was a cheap/easy fix. I tow a tritoon with it, we just got back from 2 weeks at 2 different lakes, about 700 miles total of towing. 9-10mpg towing, 20-21mpg to/from work. It's an awesome vehicle.
Mike - You have the 3.73 gear and the build sheet. So I assume you do NOT have the heavy duty tow package as well? The additional cooling comes with the HD tow. At least on my 2016 it does.
Ah -now I'm right behind you with 76K on my (last month) new to me '17. I really like this rig and it feels like everything I've been looking for as a mature adult. It's RWD only with a 3.73 optional gear and nice OEM 20" wheels. Having that odd little idle shudder and a "more odd" chuggle when coasting (deceleration) down between 30 and 20mph -feels like the 3rd gear lock up is trying to decide what to do. My wife drievs it occasionaly and says "stop trying to find something wrong". Last week I changed plugs but got lazy and handed my new Motorcraft SP580 plugs to a fairly sharp Firestone mechanic and said "be sure to gap them at thirty, no more" (magic marker on the boxes too). Didn't seem to help the idle -maybe slightly. Yesterday I cleaned the 3 MAP sensors -same result there. Am leaning toward a 5 Star for towing a 25' RV but don't want to tune until I'm solid on the idle and coasting oddities. Also want to know what brands of oils you're using in the engine and rear diff. The Ford dealer I bought it from changed oil and the little window sticker says 5W20 don't know if it was dino or syn. I removed a pint and added Liqui Moly MoS2 anti-friction and then will start running whatever everyone here thinks best. Want to keep this rig on the road for a long time. Reply when you can. Mike
I use Mobil 1 5w30 full syn for the engine, Mobil 1 full syn gear lube for the differentials, and Motorcraft Mercon LV for the transmission and T case.
Ford recommends 5W30 oil, not 5W20.
Several times the selling/servicing Ford dealership for my 2015 Ford Expedition Limited 4x4 put the wrong oil in engine, and I had to take it back. One time the service advisor said “his guys” weren't’ used to the 5W30 requirement yet. I’m assuming he meant his “factory trained technicians” that “know my vehicle best”.
With the M1 full syn lube are you adding any Ford XL-3 Friction Modifier or Trans-X® Posi Trac® Limited Slip Gear Oil Additive to your read end? At 76k I am just noticing a groaning sound when from a dead stop I accelerate into a sharp turn left or right (like turning onto a side street from a stop sign). Since it has the LS rear end that has to be clutch packs, right?
In the rear of my '17, I used Marine gear oil and added the Ford modifier at 38K.....silent since and I'm now at 85K
So earlier this week I talked to the Ford service writer where I bought my used 2017 w/75K and he boldly stated "we use bulk 5W20 in everything unless the customer asks for something else". I'm not real concerned as the temps have remained cool here -already bought some Penzoil Platinum 5w30 for next month's change.
Question: Has anyone looked into Liqui Moly oils and additives? They've got some pretty great reviews from enthusiasts and I've added the MoS2 to my Expedition, my son's 4.0L Explorer, my lawn mower and my portable generator. The only instant improvement has been with the lawn mower. From brand new it has always puffed smoke at start up. It hasn't puffed since I added about an ounce of the MoS2. Maybe it's as good as it seems? They've even got a syn transmission fluid that meets the Mercon LV spec. What say ye?
