2015 King Ranch 4x4 - Lift, Rims, Tires, Roof Rail?? info needed..
Jet225
louisiana
I have a new to me 2015 King Ranch 4x4. I'm going to make a few changes to make it not look like your standard grocery getter. Please advise with opinion or fact for any of the items below. I've done a lot of reading on here, but i'm not completely clear on some items (mostly the lift).
I want to put new 33" AT tires on, but am concerned about rubbing. I'm willing to add the 3/2 lift that seems pretty popular, but don't want to do this if it isn't necessary to avoid rubbing. Will the front "leveling" lift be enough to not rub with 33s?
My rig is white with the dark brown bottom trim. I'm thinking of these wheels GD10 or XD829, anyone have these or seen them? What spacing would now have the tires extending out past the edge of the vehicle (don't want rocks, and dings), but would reduce the chance of rubbing? Also feel free to comment on which looks better or other ideas.
GD10.jpgGD10 XD829.jpgXD829
Is there an after market roof rail that replaces the stock rail running lengthwise of the vehicle? I'm not overly fond of the stock chrome rail look, or its height.
Are there any mods that can be done to pep up the 3.5L eco that don't compromise integrity a whole lot? I just bought my wife a 2019 Stealth Edition & that thing has a lot more get-up than that 2015 does. I'm worried after the tires it will need a bit more HP.
What is your opinion on winch bumper options that don't look like a cattle gap hanging off the front. I'd like the keep the front looking as clean as possible.
Thanks for any input or comments.
16plati
VA
View attachment 31244GD10 View attachment 31245XD829
I know a guy on here running no lift with 285/60/20 on 20x9 +25 wheels. No rubbing. No trimming. 33.46” y’all and like 11.2” wide. That’s gonna be the max tire size for that offset without lifting though
Flexpedition
midwest
You asked for opinions.... Neither wheel does anything for me. Its the bead locker thing around the outside edge. The brown/bronze on the GD10 would compliment the truck though. Your stock wheels might look fantastic with the right A/T tires.
If your KR is a short wheelbase, non-EL, take a look at a 2003 Expedition roof rack. The bars are adjustable front/rear and can be completely removed, leaving just the low profile track. You should be able to find one of these for next to nothing. Probably easier to install one of these than to just ditch the original and contend with the holes.
I'll add some photos for reference:
J
Jet225
louisiana
That looks exactly like what I’m looking for. Do you think that rack bolts up to the same location as mine? It is the short wheel base. There is a u-pull it salvage yard near me that probably has a unit like that.
Flexpedition
midwest
I think it will. My 2008 came with the 2003 rails from the factory (no cross bars) and to be honest I don't think much, if anything, has changed with the shell of the vehicle from 03-17. Salvage should be full of 03's, good luck!
16plati
VA
5 star 93 performance tune. 100hp 100tq tonthe wheels. My 16 on 35s hauls ass now with that tune. Ppl are surprised all the time!
J
Jet225
louisiana
Looking at the wheels i listed, i can only find a set with a +15 spacing. Do you think that would cause issues? I don't know much about what the spacing numbers mean.
Thanks
16plati
VA
Thanks
+15 is going to move your wheels out 1.15” farther out from where thy are now.
iamretired
Pahrump, Nevada
I have the exact same vehicle, by vin number, as members have commented that it is a marketing thing, but not a real 2015 King Ranch 4x4. I bought at an auction in february in SLC and it was a police unit 83k. It has skid plate and had a cop center console, which I swappped out with a 2017 center console, easy enough except the wiring for usb sync and 12 volt inside box light and usb ports, as wiring colors changed from 2015 to 2017 center console, which I have posted looking for help. Point is mine has no roof rack and I very interested to know for sure if same screw holes of the 2003 would bolt on. At 70 years old would save me a lot of grief if I found a 2003 rack to know it would fit. Mine came with almost new wrangler duratrac 275-65r-18, which almost looks like it is it lifted. I added bull bars to the front for running around in rural nevada, with all the burros, cows, coyotes, and more to lessen any damage that may happen in dark night areas. Again if anyone could help with the console box wiring colors and right usb connection? I have a female full size usb and box has mini usb connector.
max357
