read 95scooby’s thread and went with bilsteins instead of the readylift.
31.5” is prelift height.
How do I loosen the top hat? The strut keeps spinning so I can’t loosen the nut.
Yeah I figured that out. I forgot I had that tool LOLGet yourself an impact and it’ll come right off.
What size tires you gonna run? And do you know about the CCD issue? Can’t tell if you have that or not on yoursYeah I figured that out. I forgot I had that tool LOL
Ditch the airdam if you want to look more truck, less grocery getter
Steering wheel is not straight because it was probably inadvertently knocked off center during your installation process. Looks sharpWheels installed (and properly torqued to 150ft-lbs).
Removed the front air dam.
Review:
Wildpeak M/T aren’t terribly loud, but definitely louder compared to the OEM Rubber.
Even on OEM wheels, the Bilsteins were much firmer. My wife drives the rig as well and noticed it picks up all the bumps on the road. That being said, she isn’t dissatisfied with the new setup but she does feel the difference as well.
Alignment is tomorrow, but I noticed after I installed the new wheels and tires, the steering wheel is no longer straight. I assume it’s due to the wider and taller tires?
Nonetheless, at least now we have a great looking grocery getter
What offset are those wheelsWheels installed (and properly torqued to 150ft-lbs).
Review:
No center caps?+18
That definitely makes sense. I know when I had the OEM wheels on, the wheel was straight (or at least now I’m paying attention to it). Thanks for the reply![]()
+18
