scoot0073
Georgia
Today I bought a new oil pump, serpentine belt, oil sending unit, antifreeze ,new water pump, timing chain set with cast iron chain tensioners, oil filter, motor oil.
All because I need to replace my timing chain so I figured might as well replace all these items as well.
Still got to get the lower radiator hose and since I have a oil cooler that's $168 hose at AutoZone
Sent from my ONEPLUS A6013 using Tapatalk
ManUpOrShutUp
Checked the suspension and found nothing amiss aside from the dying front wheel hub assembly, which I already knew about. Changed the oil also and sent off a sample to Blackstone.
SomeENG
Los angeles
I checked my front suspension and steering, all my boots are ripped and the bushings are looking worn. I've been looking at a mevotech set on rockauto for $300.
seems to be the best quality for the money I can find.
https://www.rockauto.com/en/catalog....4l+v8,1354531,suspension,front+end+kit,15413
ManUpOrShutUp
ManUpOrShutUp
Did the rear brakes and rotors today. Raybestos rotors (same manufacturer as my AC Delcos in the front) and Akebono pads. Just like the fronts, no complaints with this setup.
scoot0073
Georgia
Bought the valve covers gasket set with grommets. Gotta get the cam shaft locks and the crank position tool..
Blksmk
Canada/USA
Installed my bush bar, ordered full brakes looking at removing the air bags in all 4 corners. Looking at headers and full exhaust got my spare block at the shop, got my hx35 turbo
scoot0073
Georgia
The Cam Shaft holding tool and Crank position tool will be here today. Man I'm Soo ready to get my rig back on the road again.
scoot0073
Georgia
More parts came in today, getting closer8e0dd597eb9a3bb1a84eefb399886a59.jpg99af852a9769404a86bfee7c9e6b174e.jpg
