Rechrome radio knobs
rwmorrisonjr
Memphis, TN
Does anyone know how to rechrome radio knobs or what I need to do? The radio I bought has the chrome rubbed off the knobs, and the "chrome" paint pen doesn't look right. Would I need to replace the knobs or is there a way to rechrome them without replacement?
Cyclone
I was going to suggest the Chrome paint pen, but I see you have already tried that. Not sure what other options are out there for you.
Dustin Gebhardt
Tulsa, OK
I'm a metal finishing engineer with 18 years of experience in the plating industry. If the knobs are plastic, then there is no good way to rechrome them. The cost to do so is cost-prohibitive. In most plating-on-plastic manufacturing sites, they simply trash the scrap because reworking them is too expensive. You are better off just buying new knobs (if possible).
If the knobs are metal, then they probably can be re-chromed. Typically a shop will strip the old chrome off, clean the surface, and plate them as needed. Some polishing steps might be needed for a high-gloss finish. Cost could be as low as $20 to over $200, depending on the quality and amount of processing required.
Cyclone
I am curious. Would you mind posting a picture of the results that you got using the Chrome pen?
chuck s
".. or just make them all black" would be my recommendation. Or whatever color blends best. Rattle can of paint from the hardware store (probably a can at your house somewhere).
As an aside: what's putting wear on the knobs? I can't recall the last time I touched a rotary radio knob in any car.
-- Chuck
rwmorrisonjr
rwmorrisonjr
Memphis, TN
-- Chuck
No clue. I bought the radio used from LKQ, so it could be anything. I don't use them either, but want them to look right.
jeff kushner
North of Annapolis
I'm a metal finishing engineer with 18 years of experience in the plating industry. If the knobs are plastic, then there is no good way to rechrome them. T (if possible).
There is at least one exception to this. A few years back Jay LEno had a guy on who had a 2 part liquid plastic Chrome. I bought a kit a couple years ago and in fact, you can "chrome" plastic but it is not shiny, not bad but not shiny. I can get more info, post a link on this if the OP is interested.
I think the kit was around 80 bucks or so.... I do restorations so I also do my own plating.
I have a pic of a white plastic spoon half-chromed somewhere I can post....
jeff
rwmorrisonjr
rwmorrisonjr
Memphis, TN
jeff
Jeff, please post a link. $80 is a bit steep for me, but I'm curious about it. Still trying to locate replacement knobs. The one place that lists them is "sold out" and doesn't know when or if they'll have them back in stock. They were actually kind of snotty about it, saying I could look on Ebay or local junk yards for them.
Gregg Eshelman
Idaho
Spaz Stix Ultimate Mirror Chrome. Comes in a small spray can or a bottle for airbrush application. If the surface you spray this on is shiny glass smooth, you'll get a mirror finish. Takes several coats. Then when that's totally dray apply their special clear coat for the chrome paint.
It's made for spraying on the inside of clear lexan radio control car bodies. I used it on the inside of cast clear urethane emblems for old cars. Spray it on glass or smooth clear styrene and you have a mirror, both on the paint side and looking through the substrate.
Rustoleum has a similar paint, larger spray can, lower price. Also available in a "gold" color. But unlike the Spaz Stix paint the Rustoleum is only good for back side application on glass, urethane, probably lexan or polycarbonate. Its solvent carrier attacks styrene. The paint side stays dull - works exactly the opposite of any other "chrome" paint that has the paint side shiny but the substrate side dull.
What I'd try with the knobs is sand off any remaining "chrome" (it's actually vacuum vapor deposited aluminum) then spray the chrome areas with a sandable lacquer primer. Wet sand with several grits of paper. Finish with at least 2000 grit. Dry off then apply a second coat of primer. A kit of MicroMesh sheets should get it to a gloss finish.
Spaz Stix has white and black backing paint for their mirror chrome. White gives it a brighter look, black darkens it some, making it look more like nickel. Apply a coat of the backer paint and let dry. This can be difficult to get super smooth with the spray cans. Airbrush would probably work best, for the whole job. Know anyone with an airbrush?
Then you can spray on the mirror chrome, let that dry then the clear.
The key to applying clear over "chrome" or any other paint is the solvents. Some companies have clears with a solvent chemistry designed to not attack what's used in their other paints. Some use the same chemistry across their whole product line, which can make it difficult to impossible to spray one color or clear over another. Some brands have recommendations for minimum flash time between coats but if you wait more than X time you must wait Z much longer time before applying more.
For mixing brands, look for very different chemical names in the ingredient list. For example a xylene based paint may not attack a tolulene based paint or visa-versa. Clear lacquer can usually be sprayed over enamels, as long as the enamel has dried for plenty of time. Used to be that one could get all kinds of colors of lacquer in spray cans but now you're lucky if you can find anything but clear and primer.
Another paint to look at for chrome is ALSA. They have some great looking stuff but it's expensive. 'Course you get more paint for the money but for a couple of knobs three little cans from Spaz Stix for backer, chrome, and cleat coat will cost a lot less than just the chrome can from ALSA. 'Course you could go wild and do some chrome flames on your Ex with the ALSA paint while you're doing the radio knobs.
